Username Post: 09 Impala rear defrost switch/ timer        (Topic#359372)
Henrys57wagon
Henrys57wagon
Loc: Ontario
Reg: 04-15-06
01-04-20 07:24 PM - Post#2783706
For years the rear defrost timer never timed out. Now the defrost works intermittently.
I swapped the relay and the old one works in the start socket.
I pulled up the carpet at the pass door and checked for power in the feed which works intermittently which leads me to think it is the timer.
Any help would be appreciated. Thanks.
57 B/A wagon, 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 07 2500HD with 26 Prowler 5th wheel, 09 Impala LT, 2- 51 HenryJ's,
http://www.picturetrail.com/sfx/album/listing/use r...
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-05-20 04:37 AM - Post#2783718
    In response to Henrys57wagon
Do the outside mirrors defrost while the rear window does not?
Henrys57wagon
Henrys57wagon
Loc: Ontario
Reg: 04-15-06
01-05-20 05:54 AM - Post#2783719
    In response to junkman104
I have to add that the switch lights up every time I push the button.
The mirrors have never worked that great since I have had the car, however the defogger always worked up till now. Sounds kind of funny!
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-05-20 03:49 PM - Post#2783764
Wiring diagram shows power to both when relay energizes. I need to figure out how to post it for you.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-06-20 05:15 AM - Post#2783800
Got it, check Batt3 fuse also.
Henrys57wagon
Henrys57wagon
Loc: Ontario
Reg: 04-15-06
01-09-20 05:38 AM - Post#2784036
Thank you, will have to do more testing.
Execution time: 0.134 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:37 PM
