Username Post: CR with a turbo charger        (Topic#359351)
ejw71
Loc: Bella Vista, AR
Reg: 01-19-01
01-02-20 07:37 PM - Post#2783545
On a sbc what street compression ratio can be used with a turbo charger? Ed
01-03-20 07:30 AM - Post#2783592
    In response to ejw71
Not an expert here, but intended boost, quality of engine build can dictate compression ratio.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-04-20 05:03 PM - Post#2783696
the answer depends on factors like engine temp
exhaust flow restrictions
fuel octane used
( race octane gas or E85 is generally going to help results)
ignition advance curve
fuel air ratio
read the links
Edited by grumpyvette on 01-04-20 05:04 PM. Reason for edit: No reason given.
01-04-20 09:58 PM - Post#2783711
just about any, as long as your ignition timing can control knock. 8-1 would be pretty normal. theres a bunch of variant factors in this.
Execution time: 0.159 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:11 PM
