43 Years of Service
Username Post: Soft brake pedal after full system install        (Topic#359296)
64 Nickey
Reg: 12-29-19
12-29-19 04:52 PM - Post#2783164
I have just finished installation of a full brake system on my 64 Biscayne. Despite multiple times power bleeding the system I am still having problems with a soft pedal. I converted the car to full power disks using your power booster/MC and big brake kits with all new lines. With the car off I barely build pressure and with the engine running the pedal goes to the floor with little effort. I bench bled the master prior to install and have no leaks. Could this master be faulty? Any info on a solution would be appreciated. Thanks
FINMAN
Loc: Burlington , Mass
Reg: 03-01-05
01-12-20 08:09 PM - Post#2784293
    In response to 64 Nickey
Sounds like the pin on the booster needs adjustment. Do a google search for adjusting power booster pin adjustment
Execution time: 0.476 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:41 PM
