Username Post: 1938 Chevrolet Master Deluxe oil filter?        (Topic#359208)
asahi1234
Reg: 06-19-14
12-23-19 10:30 AM - Post#2782743
Were is the oil filter location? I thought it would be oil canister on the firewall. Thanks for your help
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
12-23-19 03:56 PM - Post#2782765
    In response to asahi1234
For the most part, the filters were hooked to the intake manifold in front of the carb. U bolts were used to hook it up.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
12-23-19 06:25 PM - Post#2782778
They did not come with an oil filter from the factory. It was an add on. You may not have a filter. How long have you had your 38?
29-41, 42-48, 49-54 Moderator
asahi1234
Reg: 06-19-14
12-23-19 06:51 PM - Post#2782782
Just bought it a few days ago. Can I just put remote oil filter?
12-23-19 07:11 PM - Post#2782788
Yes you can. But you can change the oil. The filter is only a bypass filter, meaning that only part of the oil gets filtered at any time. Eventually all of the oil gets filtered.
Do you have a service manual yet for it? The bypass filter uses a line off of the fitting for the gage.
asahi1234
Reg: 06-19-14
12-23-19 07:41 PM - Post#2782789
I orderd manuals this morning.
12-24-19 09:52 AM - Post#2782825
I cannot find the filter in my manual, I think because the filter was added later. Someone should have and installation drawing for it.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
12-28-19 06:41 PM - Post#2783103
In 1938 the AC oil filter was mounted on the firewall. Most filters were installed later in the life of the car.
The by-pass original flters did a good job of filtering
If you will be driving only a thousand or two miles a yeAr just change oil once a year and no filter is necessary unless you lie in aa dusty area.
Edited by Gene_Schneider on 12-28-19 06:42 PM. Reason for edit: No reason given.
Execution time: 0.161 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:05 PM
