Username Post: tbi coil conversion        (Topic#359193)
danbrown
Reg: 12-22-19
12-22-19 11:49 AM - Post#2782676
I am currently putting a tbi unit off a 1995 chevy pickup on a 1974 chevy pickup. I have the tbi distributor from the 1995, but want to use an old style cylindrical coil (non-tbi). Has anyone done this, and, if so, how did you wire it?
Texasray
Texasray
Reg: 11-01-16
01-17-20 08:46 AM - Post#2784530
    In response to danbrown
It's been awhile since you posted this up, still working on it? I've not tried to put a old oil filled coil on where a newer system module type epoxy coil was but... the wiring is about the same.
The pink wire to the '95 system comes from ignition, it also pigtails out to excite the module. The white wires go from the ignition coil to the tach and the module. The module then grounds the white wire to the coil in a pulse just as the points would. The trick here is that the oil filled coil would provide the protection for the electronic circuit that is in your distributor. You would need to find a resistance value for the primary side of the epoxy '95 coil that can be found in a old style oil filled coil. You may find a compatible coil in the aftermarket. Maybe an older Accell or Mallory unit, if I remember some of those units from the '80's would work with their point units and the first electronic units. But I am dealing with some old brain cells here so...
Good Luck with your project.
Sam
IgnitionMan
Reg: 04-15-05
01-26-20 05:21 PM - Post#2785243
Stock oil filled canister coil works on both full voltage (NO resistor), and mounts off the distributor.
A small diameter body EFI HEI distributor is available, look into Rock Auto, 1990 or so V8 distributor that has the 8 pin HEI with one edge protruding past the relief for it in the cap.
I would have posted pictures of this stuff, but it costs money I don't have now. Rock Auto has pictures of this distributor.
Execution time: 0.134 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:27 AM
