Username Post: Crank no start issue        (Topic#359155)
marandell
Loc: LA
Reg: 12-17-19
12-17-19 08:03 PM - Post#2782367
Hey guys new member here and I'm having a issue with my baby "the ghost". It's a 01 Chevy Silverado 2500hd.6.0 v8 vortec I've replaced fuel pump(watery gas). I've purged the system, checked filter, plugs, wires. Good fuel pressure at the rails.it's getting fire but will not crank.It turns over wth no problem but won't start. It almost cranks on ether. Idk what else to do. Anyone else have this issue?
12-18-19 10:52 PM - Post#2782462
    In response to marandell
crank and turns over are often mixed and confusing terms. crank would mean that the engine is rotating while trying to start but will not start. known as, crank no start. if it has spark then timing may not be correct. what is watery gas?
welcome to ct, you hit the jackpot of chevy knowledge.
Edited by bobb on 12-18-19 10:54 PM. Reason for edit: No reason given.
redvett01
redvett01
Loc: Wickenburg, AZ
Reg: 10-23-03
12-19-19 02:26 PM - Post#2782513
    In response to bobb
Check fuel pressure should be 55-62 with 62 preferred.
K1500 04 Silverado EXT
Execution time: 0.125 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:34 AM
