Username Post: 41 disc brake conversion        (Topic#359133)
jbouchard
Reg: 08-07-12
12-14-19 04:42 PM - Post#2782159
Hello All.
Just wondering what others have setup to put disc brakes and and a power brake booster on a 41 special deluxe. Right now I just have the stock setup (shoes and drums), but want to know what other cars/years have disc brakes that will fit the 41.
Thanks,
Judson
1971BB427
Loc: Portland,Or
Reg: 12-06-09
12-14-19 06:30 PM - Post#2782167
    In response to jbouchard
There are no kits or direct fit disc brakes from other year Chevys that will bolt right on. And the disc brake kits available for a '41-'49 Chevy car will always come with a later 5x4.75" bolt pattern. So if you still have the original 6 bolt wheels you'll be replacing them with 5 bolt Chevy pattern wheels.
This is one kit for $400 that is a bolt on. But what they don't include is a new master cylinder, or proportioning valve, and both should also be added when you swap in disc brakes. I would always use a dual master and proportioning valve when running a disc/drum setup.
https://www.ebay.com/itm/1941-1948-Chevrol et-front...
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
joems
Reg: 11-17-11
01-15-20 02:00 PM - Post#2784441
I actually have one of those kits in the response above that I never used if you are interested.
Joe
Edited by joems on 01-15-20 02:00 PM. Reason for edit: No reason given.
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
01-24-20 01:56 PM - Post#2785087
Use a 50s corvette for your Master cyl set up for under neath the floor, thats what I did on my 47
Fits well
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
01-24-20 02:25 PM - Post#2785091
    In response to Broo102
How does a 50's vette master work with disc brakes?
1971BB427
Loc: Portland,Or
Reg: 12-06-09
01-25-20 07:16 AM - Post#2785131
It wont work. Need a dual master, and an adjustable proportioning valve to convert to disc brakes.
01-25-20 09:13 AM - Post#2785138
    In response to 1971BB427
Correct, that was my point. Lol
1971BB427
Loc: Portland,Or
Reg: 12-06-09
01-25-20 04:25 PM - Post#2785163
Yes, I figured that's where you were going. But another issue with a 50's Corvette master and disc brakes is the bore diameter of that master, and lack of pressure to properly function with disc brakes. Need a proper sized master that's designed for disc/drum system, so it will brake like a car made originally with disc/drums.
01-25-20 07:01 PM - Post#2785176
Again, correct, the master should be disc/drum by design. I have this set up on my 51, common vette master, 1 1/8 bore, 10# residual plumbed into the rear, matching prop valve of course. Pedal is a little low as expected, a 1" bore would provide a better pedal feel, but the brakes work great, double diaphragm booster also.
Broo102
Broo102
Reg: 09-30-14
01-29-20 01:49 PM - Post#2785421
I used a vette M/C maybe it was from sixties?, works fine with my front disc brakes, drums in rear
I used an external proportioning valve
Thanks!
Bru
John 3:16
Edited by Broo102 on 01-29-20 01:49 PM. Reason for edit: No reason given.
1941srodcoupe
Reg: 07-08-03
02-07-20 05:49 PM - Post#2786085
What is your end game goal? R U going to stay stock suspension 4ever? If not wait & change it all at once. If staying stock like said above u may loss your 6 lug wheels. I'm not sure what is offered for under floor master cylinder. If staying under floor U will need the proper residual check valves. Don't mean to insult you but depending on your skill level it can get tricky and unsafe pretty quick. Do your homework B4 U jump into a project like this and keep asking ?s.
Broo102
Broo102
Reg: 09-30-14
02-12-20 08:46 PM - Post#2786401
    In response to 1941srodcoupe
If youre addressing me, I, running a Camaro rear end with new leaf springs and shocks
My M/C works fine with the external adjustable valve in line with the rear brakes
Thanks!
Bru
John 3:16
1941srodcoupe
Reg: 07-08-03
02-14-20 04:23 PM - Post#2786526
Sorry that was meant for the OP. He seems to have left the scene.
Edited by 1941srodcoupe on 02-14-20 04:23 PM. Reason for edit: No reason given.
Execution time: 0.143 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:48 AM
