jbouchard
Reg: 08-07-12
12-14-19 05:42 PM - Post#2782159
Hello All.
Just wondering what others have setup to put disc brakes and and a power brake booster on a 41 special deluxe. Right now I just have the stock setup (shoes and drums), but want to know what other cars/years have disc brakes that will fit the 41.
Thanks,
Judson
1971BB427
Loc: Portland,Or
Reg: 12-06-09
12-14-19 07:30 PM - Post#2782167
In response to jbouchard
There are no kits or direct fit disc brakes from other year Chevys that will bolt right on. And the disc brake kits available for a '41-'49 Chevy car will always come with a later 5x4.75" bolt pattern. So if you still have the original 6 bolt wheels you'll be replacing them with 5 bolt Chevy pattern wheels.
This is one kit for $400 that is a bolt on. But what they don't include is a new master cylinder, or proportioning valve, and both should also be added when you swap in disc brakes. I would always use a dual master and proportioning valve when running a disc/drum setup.
https://www.ebay.com/itm/1941-1948-Chevrol et-front...
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
joems
Reg: 11-17-11
01-15-20 03:00 PM - Post#2784441
I actually have one of those kits in the response above that I never used if you are interested.
Joe
Edited by joems on 01-15-20 03:00 PM. Reason for edit: No reason given.
Broo102
![Broo102](https://www.chevytalk.org/fusionbb/images/avatars/10.jpg)
Loc: Huntington Beach, CA.
Reg: 09-30-14
01-24-20 02:56 PM - Post#2785087
Use a 50s corvette for your Master cyl set up for under neath the floor, thats what I did on my 47
Fits well
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
47 Chev. convertible in progress |
01-24-20 03:25 PM - Post#2785091
In response to Broo102
How does a 50's vette master work with disc brakes?
1971BB427
Loc: Portland,Or
Reg: 12-06-09
01-25-20 08:16 AM - Post#2785131
It wont work. Need a dual master, and an adjustable proportioning valve to convert to disc brakes.
01-25-20 10:13 AM - Post#2785138
In response to 1971BB427
Correct, that was my point. Lol
1971BB427
Loc: Portland,Or
Reg: 12-06-09
01-25-20 05:25 PM - Post#2785163
Yes, I figured that's where you were going. But another issue with a 50's Corvette master and disc brakes is the bore diameter of that master, and lack of pressure to properly function with disc brakes. Need a proper sized master that's designed for disc/drum system, so it will brake like a car made originally with disc/drums.
01-25-20 08:01 PM - Post#2785176
Again, correct, the master should be disc/drum by design. I have this set up on my 51, common vette master, 1 1/8 bore, 10# residual plumbed into the rear, matching prop valve of course. Pedal is a little low as expected, a 1" bore would provide a better pedal feel, but the brakes work great, double diaphragm booster also.
Broo102
Reg: 09-30-14
01-29-20 02:49 PM - Post#2785421
I used a vette M/C maybe it was from sixties?, works fine with my front disc brakes, drums in rear
I used an external proportioning valve
Thanks!
Bru
John 3:16
Edited by Broo102 on 01-29-20 02:49 PM. Reason for edit: No reason given.
1941srodcoupe
Reg: 07-08-03
02-07-20 06:49 PM - Post#2786085
What is your end game goal? R U going to stay stock suspension 4ever? If not wait & change it all at once. If staying stock like said above u may loss your 6 lug wheels. I'm not sure what is offered for under floor master cylinder. If staying under floor U will need the proper residual check valves. Don't mean to insult you but depending on your skill level it can get tricky and unsafe pretty quick. Do your homework B4 U jump into a project like this and keep asking ?s.
Broo102
Reg: 09-30-14
02-12-20 09:46 PM - Post#2786401
In response to 1941srodcoupe
If youre addressing me, I, running a Camaro rear end with new leaf springs and shocks
My M/C works fine with the external adjustable valve in line with the rear brakes
Thanks!
Bru
John 3:16
1941srodcoupe
Reg: 07-08-03
02-14-20 05:23 PM - Post#2786526
Sorry that was meant for the OP. He seems to have left the scene.
Edited by 1941srodcoupe on 02-14-20 05:23 PM. Reason for edit: No reason given.
Mel Foye
![Mel Foye](https://www.chevytalk.org/fusionbb/images/avatars/0.jpg)
Reg: 09-29-00
03-01-20 01:36 PM - Post#2787681
My personal experience varies. 1962 Corvette lost most of the drum brakes due to dirty fluid in stock MC. Honed and new kit and worked fine till I hit a big run of water and standing on the pedal barely slowed the car. So I said goodby to front drums and went to disc on the front.
Stock MC, no power unit, no pro-valve and no residual pressure valve. Great brakes now and setup has 250,000 miles on it.
When I pull engine will likely go to dual MC for the back up safety. Used dual set up in my 30 rod.
It Was On Fire When I Laid Down. |
jbouchard
Reg: 08-07-12
03-15-20 05:54 AM - Post#2788671
In response to Mel Foye
Hello All,
Thank you for the responses and information. This was simply an inquiry for something I would like to do in the future and I will keep this information. My goal is just to make the car safer and more drivable.
Judson
jbouchard
Reg: 08-07-12
01-02-23 09:57 AM - Post#2853108
Update:
Its been a while, but..
Ended up purchasing and installing an indpendent front suspension from Southern rods with the disc brake and power steering option.
Found a t5 from a 1993 Chevy S10 which fit my 235 engine.
Replaced the rear with a 67 Mercury rear.
Right now in the process of tackling how to hook up the power steering as (ironically) there is not a lot of room to run an additional belt/ps pump.
Not there yet, but making progress.
Thanks for everyones help.
Edited by jbouchard on 01-02-23 05:02 PM. Reason for edit: No reason given.
01-29-23 11:34 AM - Post#2853875
i would be looking for the smallest pump i can find with mounting tabs i can fab to. remote reservoir and done.
