Username Post: 2012 Tahoe Piller Trim w/Handle        (Topic#359089)
bluegoose
Reg: 12-13-14
12-09-19 03:24 PM - Post#2781814
Does anyone know if there is such a thing as a driver's side windshield A-pillar with a handle built into it? Basically, a mirror image of the passenger's side.
A few months back, my dad purchased a 2019 Silverado. It has a handle on the driver's side to help the driver enter the vehicle. Since my mother has severe back trouble, it has proven to be an asset, and I'm trying to figure out if we can retro-fit her older Tahoe with the same setup.
Any input will be appreciated!
Senior Moderator
12-10-19 07:59 AM - Post#2781868
    In response to bluegoose
I haven't seen any older model GM trucks with this. Ford has been doing it since the 2008 model I think? I know that in wreckers equipped with this handle I've smacked it a few times while maneuvering in parking lots and bent fingers backwards hurts pretty badly.. the Ford handle is grossly oversized, though.
If you look at the passenger A-pillar grab handle you'll find there's a decent amount of support behind the trim panel. On GMT400 trucks (88-98 body) there's a bracket welded to the pillar with a couple captive nuts in it, and the handle which is vinyl-covered plastic bolts into those. I retrofitted a 1994 cab (pre-handle) with a handle and interior from 1995-up; it was a bit of work! You could do the same thing for the driver side, though. I chopped the pillar out of a newer cab which allowed me to drill the welds out (windshield in the way otherwise), made a template for where to place it, and welded it to the older cab. The interior trim will be the tricky part if you want it to look factory since there's no existing driver side A-pillar trim with grab handle. Otherwise, a couple of carefully marked and drilled holes, shaped afterwards with a Dremel, would probably work out just fine.
Just for clarity's sake here's the GMT400 pillar bracket after being welded in. Notice how the captive nuts are on the back side of the bracket so there's no chance they can pull through; the bolts sandwich them to the bracket itself.
Just be sure to cover everything well before welding! I taped cardboard to the windshield, covered the dash, floor, etc. with heavy moving blankets so that no weld spatter would damage the interior. It's just a few good welds (5 in my case) so it didn't take long.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-13-19 08:04 PM - Post#2782110
    In response to someotherguy
I think GM was about the only ones to not have one until around 2010.
My 03 Tundra has one, Fords, Dodges, Nissans have them.
Being a 2012 you may have the bracket there.
If you do it will be as simple as buying the handle and trim.
Old School GM fan FOREVER
bluegoose
Reg: 12-13-14
01-06-20 04:54 PM - Post#2783852
Wow....I have to ask: was all of that work worth the handle? That got involved fast lol.
Seriously, thank you for the information. I searched all over the internet and I couldn't find where anyone talked about it being aftermarket or, in your case, custom. I figured there would be drilling, but not as much welding.
Anyway, I guess she is going to have to live with it until the new Tahoe comes around....
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-06-20 06:27 PM - Post#2783862
lol
Senior Moderator
01-06-20 09:15 PM - Post#2783882
Excellent question! Yes, it was - I converted the interior from 1994 to the 1995-up style, while at the same time converting from a 6.5 turbodiesel to a Vortec 7.4. Other than the VIN you pretty much couldn't tell the truck's true year.
The grab handle was just a tiny piece of the bigger picture.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-07-20 07:11 PM - Post#2783954
Jealous.
Sounds just like me
Execution time: 0.376 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:33 PM
