Username Post: 1977 power steering        (Topic#359083)
bigfenders
Reg: 08-08-19
12-09-19 12:16 PM - Post#2781792
Been a few years since I've posted here...since selling my 63 1/2 ton I've been looking for a project.
Found a 1977 1/2 ton chevy manual trans...manual brakes which for me is doable but no power steering.
Since both of my shoulders have been repaired I do need the power steering.
When I converted my 63 to PS it was easy and pretty cheap to do.
Checking around for a conversion kit for the 77 sounds like I need a rack and pinion set up which is pretty pricy.
Any words of wisdom?
12-09-19 03:12 PM - Post#2781811
    In response to bigfenders
Welcome back.
I've never done a conversion. My first thinking is parts are plentiful for these trucks. A good donor will have almost everything needed. Holes are drilled into the frame.
Rack and pinion is for true show truck upgrades. For me, stock is good. Reliable too. Let me look around for a write up.
Mean while, go to www.lmctruck.com
Look at the parts needed and what you have now.
100 CHEVY
Deceased Member RIP
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
12-09-19 03:20 PM - Post#2781813
I added the factory p.s. to my 78,C-10.
Very easy to do.
You need the correct pump,pulleys,belt and mounting brackets with hoses.Then,you need to get a power steering gear box(with the pitman arm) to mount on the frame.Most of these parts can be had at the U-Pull-It yard.
That's all except for installing it all on the truck.
You'd have to do all this and more for a rack install,plus it will cost much more.
Mike.
Big fenders
Loc: Tucson Arizona
Reg: 04-30-04
12-11-19 06:59 AM - Post#2781934
    In response to 100 CHEVY
Thanks guys for the info...ended up going a different direction
Merry Christmas to all
Bob
Execution time: 0.479 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:16 PM
