Username Post: recirc position still turns on a/c even when a/c button light is off        (Topic#359065)
barking spider
Loc: Phoenix
Reg: 04-26-12
12-07-19 02:19 PM - Post#2781671
Trying to get heat but recirc position still turns on a/c even when a/c button light is off. Is this normal? Or is there a fix? Single zone. 2000 Silverado LS
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-07-19 04:47 PM - Post#2781679
    In response to barking spider
It is if you have it on defrost. The A/C acts as a dehumidifier.
Greg
'00 Explorer XLT 4.0 V6 Auto
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-08-19 08:40 AM - Post#2781703
    In response to CowboyTrukr
Exactly.
If this is occurring while in DEF, DEF/FLOOR it is normal.
If it is not then I suspect bad controls
Old School GM fan FOREVER
barking spider
Loc: Phoenix
Reg: 04-26-12
12-16-19 10:07 PM - Post#2782310
    In response to rockfangd
It is not in defrost when this happens. What part of the controls would be bad and in need of repair/replacement?
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-17-19 05:52 PM - Post#2782360
From my experience the dash controls are very common.
That is the main controls for the climate control
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
12-20-19 02:55 PM - Post#2782568
Sounds like what I had happen.I found this on another site:
A re-calibration may fix you up. Try disconnecting the battery for a few minutes. Reconnect it. Or remove the HVAC/ECAS fuse for a minimum of 10 seconds.
Re-install the HVAC/ECAS fuse.
Then turn the key to the on position, but
don't start. Don't touch the HVAC controls. Let them do whatever that
want to do. Air flow may change outlet points during this time. Wait
about 1 minute. Turn key off. Opening and closing the door can
make a difference as the vehicle controls see this as "cycle"
completion. Next start the vehicle and drive it a short distance and see
how it performs. You may indeed need to replace an actuator.
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
Execution time: 0.295 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:47 PM
