barking spider
Loc: Phoenix
Reg: 04-26-12
12-07-19 02:19 PM - Post#2781671
Trying to get heat but recirc position still turns on a/c even when a/c button light is off. Is this normal? Or is there a fix? Single zone. 2000 Silverado LS
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-07-19 04:47 PM - Post#2781679
In response to barking spider
It is if you have it on defrost. The A/C acts as a dehumidifier.
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
"The only thing necessary for evil to triumph is for good men to do nothing" Sir Edmund Burke |
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-08-19 08:40 AM - Post#2781703
In response to CowboyTrukr
Exactly.
If this is occurring while in DEF, DEF/FLOOR it is normal.
If it is not then I suspect bad controls
Old School GM fan FOREVER |
barking spider
Loc: Phoenix
Reg: 04-26-12
12-16-19 10:07 PM - Post#2782310
In response to rockfangd
It is not in defrost when this happens. What part of the controls would be bad and in need of repair/replacement?
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-17-19 05:52 PM - Post#2782360
From my experience the dash controls are very common.
That is the main controls for the climate control
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
12-20-19 02:55 PM - Post#2782568
Sounds like what I had happen.I found this on another site:
A re-calibration may fix you up. Try disconnecting the battery for a few minutes. Reconnect it. Or remove the HVAC/ECAS fuse for a minimum of 10 seconds.
Re-install the HVAC/ECAS fuse.
Then turn the key to the on position, but
don't start. Don't touch the HVAC controls. Let them do whatever that
want to do. Air flow may change outlet points during this time. Wait
about 1 minute. Turn key off. Opening and closing the door can
make a difference as the vehicle controls see this as "cycle"
completion. Next start the vehicle and drive it a short distance and see
how it performs. You may indeed need to replace an actuator.?
