Username Post: 3 point harness with the Jack storage plate        (Topic#359025)
56db
Loc: Scotts Valley, CA (95066)
Reg: 01-29-13
12-03-19 04:07 PM - Post#2781455
I am installing a Juliano's 3 -point harness kit in my 56' Chevy truck.
If anyone has done this, what did you do about the jack storage plate and hold down. The plate is located right where the holes for the belt brackets need to be drilled.
Did you remove the plate or did you leave it in place and drill holes through the plate it. Either way the jack needs to relocated. Any ideas on the best way to do this?
DB
Execution time: 0.134 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:40 AM
