Username Post: High temp after new thermostat install        (Topic#359023)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
12-03-19 12:16 PM - Post#2781445
Hey guys. I put a new intake manifold and new thermostat. After draining all the coolant, I refilled it with coolant flush and distilled water. I also had the heater on full. I went to drive it around the neighborhood and the temp gauge went to HOT. I turned around to head home and the temp went down to 3/4 hot. I'm concerned since the old thermostat only went 1/4 temp. When I drained the coolant I was on a little bit of inclined driveway. I filled it with 2 containers of coolant flush and 4 gallons of water. I was surprised that it didn't take more water because the coolant capacity is 18.5 quarts.
Any ideas on why the temp gauge went up so high in such a short drive and went back down again?
corvesy
corvesy
Reg: 08-07-08
12-04-19 06:02 AM - Post#2781477
    In response to Eth727
Its possible you may have a faulty thermostat ( even thought its new). You could remove the thermostat and put it in a pot of heated water and see if it opens.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
12-04-19 07:16 AM - Post#2781481
    In response to corvesy
Is the thermostat in backwards?
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
12-04-19 12:21 PM - Post#2781489
    In response to Tri5man
I put it in the correct way. Do you think there might be air in the system?
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
12-04-19 04:52 PM - Post#2781503
I think the reason you did not take as much fluid as you thought it should was either there was still some in the system or air in the system.
Possible old or new stats were faulty. Were they both the same temps?
Las Vegas odds are on air in the system.
ragtp66
ragtp66
Reg: 12-09-07
12-05-19 10:08 PM - Post#2781569
Where is your temperature sending unit located? In the head or in the intake?
Did you use teflon tape to install it?
Is the sending unit new? aftermarket/reproduction or original?
I would get an IR gun and see what your ACTUAL temperatures are reading. If you are using teflon tape on the sender threads you need to remove it and use thread sealer. Teflon tape interferes with the grounding which is why the factory never uses it. If you did not I would also go back and use thread sealer on your intake bolts as well as it keeps oil from wicking up the bolts and puddling on the intake.
Toys:
1987 Sea Ray Pachanga 22
1belair1954
Reg: 12-24-12
12-05-19 10:35 PM - Post#2781570
    In response to ragtp66
I used to have a 34 chevy Hotrod that would get an airlock a good trick is to drill 2 x 1/8" holes in the thermostat valve disc. Lets air out and thermostat still works not sure a 58 to 60 chevy has this problem?
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
12-06-19 01:17 PM - Post#2781600
    In response to 1belair1954
I had put teflon tape on the sending unit. I removed it and put thread sealant. Before I corrected the sending unit I had put pipe plugs to isolate the heater core. I still got a high temp reading hence why I removed the teflon tape on the sending unit. It is mounted on the intake manifold.
Execution time: 0.197 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:07 PM
