Username Post: Parking brake/emergency brake adjustment        (Topic#359017)
66cayne
66cayne
Reg: 08-06-08
12-02-19 05:49 PM - Post#2781411
My emergency brake will not hold the car on any hill level. The cables from the rear brakes to the adjustment cable are new, the cable hanger is installed on the trans crossmember and there is not much slack in the cables but the pedal will still travel to the floor when pushed. Should I be looking at the brake shoe adjustment?
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
12-02-19 11:05 PM - Post#2781413
    In response to 66cayne
I had a similar problem when I put my car back together last summer. I found that I had the passenger side cross member hanger in the wrong hole. It is meant to be installed in the TOP of the cross member. I had it in the bottom. Moving it to the top made a significant difference in the tension.
The other thing that helped was backing up and applying the brakes to work the adjusters. I backed up almost a 1/4 mile hitting the brakes every 50-100 feet. I then finished setting the parking brake tension on the tightener under the car.
My parking brake pedal is now fully tightened in front of the vent panel, not at the floor. Hope you have success too.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
12-03-19 04:50 AM - Post#2781415
    In response to Gaspains
Keep in mind for the self adjusters to actuate you must go forward, then back up, continuing back constanstantly limits the actuation of the mechanism.
66cayne
66cayne
Reg: 08-06-08
12-03-19 06:31 AM - Post#2781421
thanks fellows, I will give it a go!
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
12-03-19 07:28 AM - Post#2781424
Good point. I missed that in my description but did pull ahead while adjusting my own. That’s what’s great about this forum. Hive knowledge and gracious corrections! 😀
Kevin
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
Execution time: 0.166 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:30 PM
