Username Post: Camshaft part number        (Topic#359013)
ejw71
Loc: Bella Vista, AR
Reg: 01-19-01
12-02-19 09:25 AM - Post#2781387
Wanting to install a 340 hp camshaft in my 63 Corvette. Need the GM part Number? Tks, Ed
54 Vette 261 PG 3.55
60 El Camino 400/350 3.36
63 Vette 327 PG 3.36. Sold. I'm richer & not sad I kept the '54
71 Monte Carlo 350/350 2.73 my favorite
16 Corvette 460 hp. None of my '60 era drag cars ever went this fast
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
12-02-19 03:21 PM - Post#2781403
    In response to ejw71
097 camshaft. the last lt1 solid might be better off
if you do not have over 10 to 1 compression.
just mho jim
Mel Foye
Mel Foye
Reg: 09-29-00
12-08-19 04:26 PM - Post#2781734
The full number is 3736097 and the settings were .012I and.018E. Later GM came up with better cold non running lashes of .008I and .015E.
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
12-09-19 01:57 PM - Post#2781805
    In response to Mel Foye
Cold settings were better for my 327/340. Worth 1.5 mph and a .10....Musta been off previously.
Hey T @!
Joe
Mel Foye
Mel Foye
Reg: 09-29-00
12-09-19 11:33 PM - Post#2781852
    In response to wagonmaster
Those are great gains for my estimates of the time it took to do the valves. I used to use the mphs as my baseline due to small tires. The 327/250 62 Vette suddenly picked up 4 mph when I had cutouts put in the headpipes. I think the stock set up must have been very restrictive. Small changes and great results.
ejw71
Reg: 01-19-01
01-02-20 06:42 PM - Post#2783546
Thanks to Mel and all. Ed
ejw71
Reg: 01-19-01
01-04-20 11:38 AM - Post#2783678
Is the 1963 097 cam a solid lifter? Would like to know duration and lift for intakes and exhaust. Tks, Ed
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-06-20 02:16 PM - Post#2783835
hdcolo
Loc: Colorado
Reg: 08-04-17
04-13-20 08:28 PM - Post#2791106
. . Did you ever decide on which cam ? ?
Execution time: 0.107 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:05 PM
