Username Post: C5 with rod knock        (Topic#359012)
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
12-02-19 08:36 AM - Post#2781385
found a nice 99 C5 LT1 with a rod knock. I see replacement motors are a lot more than later LS junk yard motors. Any suggestions for an economical replacement? Camaro engine?
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
12-31-19 06:20 PM - Post#2783353
    In response to cooljunk
Yes Camaro or Trans Am LS1 should work just fine.
Maybe the LS1 could be fixed?
You could even use a 4.8, 5.3, or 6.0 gen 3 vortec pickup or van engine, however the iron block is heavier than the aluminum block of LS1, of those engines, I would only use a 6.0 because of the increased power potential.
Did you buy this car already?
Execution time: 0.169 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:27 PM
