Username Post: Fuel Pressure Regulator        (Topic#358998)
go_hercules
Reg: 10-27-16
11-30-19 09:22 PM - Post#2781315
I've been pondering this and thought I would bounce it off you guys. In the GM TBI system, fuel pressure is not maintained after shutdown, it is allowed to bleed off quickly. If you have rebuilt these throttle bodies, you will know that fuel from the inlet goes directly to the injector BEFORE going on the the pressure regulator. From the regulator, fuel is returned to the tank. I always thought the regulator regulated the pump pressure down to the proper value. But I think I now understand that the regulator can only bump pressure up since it acts as a restrictor.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-30-19 11:06 PM - Post#2781318
    In response to go_hercules
Correct. The pressure is created by the regulator and the needed 9+ psi gives the injectors the ability to deliver the appropriate volume. That’s why when the pressure is low, the spray pattern gets out of whack.
Greg
'00 Explorer XLT 4.0 V6 Auto
go_hercules
Reg: 10-27-16
12-01-19 04:24 PM - Post#2781343
    In response to CowboyTrukr
Thank you for the info.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-01-19 04:51 PM - Post#2781346
Yup correct.
Nice Diagram
Old School GM fan FOREVER
Execution time: 0.167 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:00 PM
