Username Post: Window regulator wheels for 1954        (Topic#358995)
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
11-30-19 10:32 AM - Post#2781290
Hi Folks,
Has anyone ever replaced the plastic wheels in your window regulator? NCA offers a plastic wheel and I think I will buy a set. What have you all done after removing the rivets? I'm thinking about threading some standoffs.
Here's the link to the NCA part. Looks like they include somekind of a plastic thing to replace the stud.
https://www.nationalchevyassoc.com/1074
Thanks,
Attachment: image0.jpg (133.51 KB) 5 View(s)
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
11-30-19 02:01 PM - Post#2781296
    In response to dsacton
Is that the original steel slider, or a broken plastic roller? I can't tell from the photo. If it's the steel slider, it should have a leather washer behind the head. These are far superior to any of the aftermarket rollers available. In the glass shop we never replaced these--they are just too dependable and rugged.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
11-30-19 03:04 PM - Post#2781301
It's a broken plastic roller. This is the side that was burned; surprizingly good condition, all things considered. The steel sliders cleaned up very well. But I need to at least replace the rollers.
So do you mean there is supposed to be a leather washer between the roller and the head on the stud? Here's a picture from the other side of the car. Thanks!
Attachment: roller.jpg (105.88 KB) 4 View(s)
Scott Acton
11-30-19 09:32 PM - Post#2781316
The leather washer was only used with the steel slider.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
11-30-19 09:54 PM - Post#2781317
Oh--I think I understand. You mean **instead of** a roller.
Scott Acton
lobucrod
lobucrod
Loc: Slaton, TX
Reg: 10-01-07
12-01-19 05:10 AM - Post#2781324
The black piece that NCA shows is a black colored steel stud.
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
12-01-19 05:45 AM - Post#2781326
    In response to lobucrod
I believe that black thing is a hollow-end rivet. These hollow-end rivets do not hold up nearly as well as a solid steel rivet, which is what we used in the glass shop anytime we had to change out a roller.
chevyivar
chevyivar
Loc: Norway
Reg: 08-30-12
12-01-19 01:05 PM - Post#2781338
Hi.
Im about to install factory power windows in my 54 and swapped out those wheels last week at the same time checking the motors.
I drilled the back side of the rivet, not much- just until i was able to tap out the rivet and wheel, then i swapped out the wheel with a new one, using the same old rivet.
I carefully welded the rivet where i had been using the drill.
A glas of water on the bench cause the plastic dont like heat, you have to be quick.
Worked for me.
Or you can fabricate if you have a lathe;)
1939 Chevrolet Master Deluxe 85
1954 Chevrolet Bel Air Sport Coupe
1954 Chevrolet Bel Air Convertible
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
12-01-19 04:14 PM - Post#2781342
    In response to chevyivar
I like it! Being in Norway, and with not a lot of '53-54 Chevs laying around, that you've devised many little tricks to repair different items. One has to do, what one has to do.
1951 Fleetline Preservation
Execution time: 0.163 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:33 PM
