Username Post: fuel and power issues--Chevy 454        (Topic#358991)
Calclements
Reg: 12-08-15
11-29-19 05:30 AM - Post#2781232
I've got a Chevy 454 that was running just fine. Then the coil went out. When I replaced that (with a new distributor cap as well), the engine began running poorly.
1. On initial acceleration, it lags and then bursts into power.
2. It'll stall out on idle. When I turn up the idle, no real help.
11-29-19 01:55 PM - Post#2781251
    In response to Calclements
What ignition system?
Calclements
Reg: 12-08-15
11-30-19 07:39 AM - Post#2781274
It is just a standard distributor sending fire to spark plugs.
11-30-19 04:39 PM - Post#2781302
Again, points, Hei?
Mel Foye
Mel Foye
Reg: 09-29-00
12-04-19 06:00 PM - Post#2781504
When changing the cap is it on straight? Mixed up plugs wires? No vacuum lines got left off or broke? Rotor removed to look at something?
Execution time: 0.189 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:11 PM
