Username Post: AC Compressor Mount Bracket        (Topic#358988)
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
11-28-19 10:36 PM - Post#2781229
Anyone using the Sanden compressor for AC in 59 with 350 engine. Would like to have a mounting bracket without using billet. Would be mounted on passenger side. Thank you
Larry
59 Impala Sport Coupe
36 Dodge Street rod..........owned 27 years
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
11-29-19 07:30 AM - Post#2781237
    In response to wings59
In the past I've used Alan Grove steel brackets that I've painted black on 350 SBC's.
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
11-29-19 09:28 AM - Post#2781245
    In response to Tri5man
Thank you Gary, I'll see what they have.
Larry
Hobart
Hobart
Loc: Chicago, IL USA
Reg: 11-18-02
11-29-19 07:30 PM - Post#2781262
I think I have the Alan Grove bracket for SBC, new in the box, if you're interested. I'll give you a nice deal on it. I'll get the part number for you Saturday morning.
I used one on my 348 in my Delray. It works very nicely.
Bill
Chicago Gearheads Car Club / Lynch Mob Racing
'59 Bel Air 2dr sedan
'68 Chevy II Nova
'72 Eldorado ragtop
'80 Z28
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
11-29-19 11:49 PM - Post#2781267
    In response to Hobart
Hold off checking part number Bill. I might have asked too soon. I'm going to look into other options. I apologize for causing you to parts chase for me.
Thank you
Larry
11-30-19 09:49 AM - Post#2781285
ac compressor is probly the biggest load on a fan belt. if the brackets are flimsy they will break. if they mount the compressor far out they need to be very sturdy. if the bracket adjusts the belt tension it makes things worse. many factory ac compressors are mounted with 4 bolts because of these problems. you also need enough belt wrap around the pulley minimum of 90 degrees should work. more is better so you can run less belt tension.
Hobart
Hobart
Reg: 11-18-02
12-01-19 10:12 AM - Post#2781332
Thank you
Hey Larry, no need to apologize - you didn't ask me to check! Anyway, it is the Alan Grove 119L brackets for SBC with long pump. Good luck with the project!
Execution time: 0.191 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:47 PM
