Username Post: 350Tubro trans        (Topic#358981)
ejw71
Loc: Bella Vista, AR
Reg: 01-19-01
11-28-19 11:39 AM - Post#2781193
Does a 350 Turbo trans bolt up to a LS1? If so, I can run it without a computer hook-up. Tks, Ed
54 Vette 235 PG 3.55
60 El Camino 400/350 3.36 awaits 292 inline six
63 Vette 327 PG 3.36 being restored
71 Monte Carlo 350/350 2.73 my favorite
16 Corvette 460 hp I never had a drag car this fast
astroracer
astroracer
Loc: Mid-Michigan
Reg: 11-27-19
11-28-19 03:07 PM - Post#2781205
    In response to ejw71
You will need an adapter. It's easy enough to google it. Here is one from Speedway.
https://www.speedwaymotors.com/TCI-Automotive-3997...
Edited by astroracer on 11-28-19 03:07 PM. Reason for edit: No reason given.
1965C-10
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
12-31-19 06:28 PM - Post#2783356
From what I have read yes it will, but one Bell housing bolt hole will be missing, no problem.
As for flexplate, all you need is the small adapter ring to align the input of torque converter snout to the LS flexplate, and maybe longer botls for flexplate to torque converter.
Also may need to open up or elongate the holes for the bolts in the flex plate.
I'll try to find a YouTube video about it I saw once.
1965C-10
1965C-10
Reg: 11-18-01
12-31-19 06:38 PM - Post#2783357
    In response to 1965C-10
https://youtu.be/8wpaqjiQXYI
Execution time: 0.194 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:25 PM
