Username Post: 1972 350 w factory air vacuum lay out        (Topic#358968)
Damskippyyy
Loc: SO CAL
Reg: 11-22-19
11-27-19 04:03 PM - Post#2781100
I’m New to this sight. In fact this is my first post. I was just reaching out to see if anybody has access to the correct vacuum line schematic for my 72. I’m trying to get the factory air sorted out. I appreciate any help anybody can give me. My fan only works on two positions is the first problem. The second problem is is that it will not divert to the defroster
Damskippyyy
1966 Malibu convertible
1972 el camino ss
1989 Chevy Silverado long bed
2016 camaro convertible 2 ss
Edited by Damskippyyy on 11-27-19 04:06 PM. Reason for edit: No reason given.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
12-13-19 05:16 PM - Post#2782097
    In response to Damskippyyy
the fan not working except on 2 positions is either the switch, the high speed fuse, the relay or the resistors. i would check the fuse first. it is located on the firewall below the windshield. it is a inline fuse. i always use a 30 amp.
i included a vacuum and electrical diagram
Attachment: 1.jpg (433.84 KB) 10 View(s)
Attachment: ac1.jpg (350.58 KB) 11 View(s)
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
Damskippyyy
Loc: SO CAL
Reg: 11-22-19
12-18-19 08:24 AM - Post#2782386
    In response to 62chevy427
thank you so much my friend
Damskippyyy
1972 el camino ss
Damskippyyy
Loc: SO CAL
Reg: 11-22-19
12-18-19 08:27 AM - Post#2782387
67 malibu eh one of my favs
Damskippyyy
1972 el camino ss
Damskippyyy
Loc: SO CAL
Reg: 11-22-19
02-07-20 08:04 PM - Post#2786093
Thank you
got vacuum figured out mostly accept for defrosters
i have a question now on brakes. i have stock power brakes disc in front drum in back i have to replace master cylinder what would be my best bet in terms of bore? also is there anything that i can do to make my brakes better without re doing everything. or converting to disc ?
Damskippyyy
1972 el camino ss
Damskippyyy
Loc: SO CAL
Reg: 11-22-19
02-07-20 08:04 PM - Post#2786094
Thank you as well got vacuum figured out accept defroster connection
Damskippyyy
1972 el camino ss
Execution time: 0.138 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:01 PM
