Username Post: No turn signals        (Topic#358953)
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
11-26-19 11:57 PM - Post#2781041
On my daughters Grand Prix...theoretically the same as a Malibu (I think). She was complaining about the turn-signals not working. She says that she checked the fuse (I love it, I brought her up to check the 1st thing 1st). I go out and try it...nothing, no lights nothing, anywheres, at any corner. I try the flasher to see if all 4 bulbs are burned out. It flashes at all 4 corners...THEN, the switch mysteriously starts to work and all 4 outside lights begin to work.
Could it be the flasher gizmo?
At present, I am waiting for more symptoms. She said that the other day, that they worked for a short time the other day and then stopped (the day before that, they were dead).
Edited by Stinky on 11-27-19 12:02 AM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-09-19 07:09 PM - Post#2781837
    In response to Stinky
Not sure what year the GP is but I would suspect the turn signal switch on the column
Old School GM fan FOREVER
craig32
Loc: PA
Reg: 08-05-07
01-01-20 05:53 AM - Post#2783378
I had the same thing with my 02 Monte, they replaced the 'turn signal module' which I assume was the flasher you're talking about and not the switch on the column, as it only took a half hour.
66 Impala (almost done!)
56 Stepside shortbed
55 Bel Air sedan
81 Corvette
02 Monte Carlo (bought new)
Execution time: 0.277 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:15 AM
