Username Post: 2007 malibu 2.2 crank no start        (Topic#358950)
Derek1985
Reg: 11-26-19
11-26-19 03:19 PM - Post#2781021
2007 malibu 2.2 crank no start fuel pump relay is good even swapped it has pressure on the fuel rail plugs are good have spark will start with starting fluid in the intake even took out the upper o2 sensor thinking the cat might be clogged any ideas
Andy J
Loc: east central Mississippi
Reg: 10-29-15
11-27-19 07:13 PM - Post#2781129
    In response to Derek1985
I had the same problem with my'02 Buick 3.1 engine.It started when I sprayed starting fluid in the intake.This car had been sitting up 4years,so I thought the fuel pump was bad.I put a new pump in and it started up immediately.
I realize you said you had pressure to the fuel rails.A new pump fixed mine.
11-28-19 01:26 PM - Post#2781201
You need to actually test the fuel pressure, then see what the specs are.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-29-19 08:32 PM - Post#2781265
Howdy and welcome to the Forum, Derek.
Like Shep said. Check the fuel pressure first. Don’t guess.
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
Execution time: 0.314 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:03 PM
