Username Post: High beams won't turn off        (Topic#358947)
Jeff1951
Loc: Bloomfield Township, MI
Reg: 11-12-18
11-26-19 02:10 PM - Post#2781014
Hello All!
A new issue just started on my '51 concerning the hi beam headlights- they won't turn off. I can't switch to low beams. I removed the dimmer switch and thought that the problem was in that but it checked out perfectly. There is continuity from the "BAT" lug to each of the low and high lugs as the switch is operated. I put the switch back in and, on the car, it doesn't seem to disconnect from the high lug. What I did find is that with the wires off the switch, there is continuity from the low beam wire to the high beam wire. This doesn't make sense. I removed the headlights to see if perhaps there was a short in the bulb. Same thing. Electrical is not my strong suit so any help would be greatly appreciated. I also posted this on the VCCA site.
Jeff
bobt
Loc: colonial heights va
Reg: 06-28-14
11-27-19 02:23 AM - Post#2781042
    In response to Jeff1951
Are you running 6 volt or 12 volt? I had to put headlight relays on my 1951 Fleetline 12 volt because I kept frying my headlight switch. bobt
Jeff1951
Reg: 11-12-18
11-27-19 06:11 AM - Post#2781049
    In response to bobt
bobt,
Thanks for the reply. The system is 6 volt, all original.
Jeff
lobucrod
lobucrod
Loc: Slaton, TX
Reg: 10-01-07
11-27-19 08:55 AM - Post#2781064
Use a jumper wire to connect the terminals on the dimmer switch plug and see I’m you have separate high and low beams. It so the switch is the problem. If still only high beams you have the high and low circuits in the wiring harness shorted together somewhere. If you just wired the switch you may have the hot lead on the wrong terminal
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
Edited by lobucrod on 11-27-19 02:23 PM. Reason for edit: No reason given.
chevyivar
chevyivar
Loc: Norway
Reg: 08-30-12
11-27-19 10:02 AM - Post#2781068
    In response to bobt
I had the same problem with a Willys MB that i have, i know you say that the switch is working, this is how i fixed mine.
A old timer told me that they would have problems with the floor switches back in the days if the switches wasnt used that often, sometimes they would get stuck in either high or low beam...
I was told to step dance on that switch like cracy, and it did the trick,after a few seconds the High/low beam was working, just a thought:)
1939 Chevrolet Master Deluxe 85
1954 Chevrolet Bel Air Sport Coupe
1954 Chevrolet Bel Air Convertible
Edited by chevyivar on 11-27-19 10:04 AM. Reason for edit: No reason given.
53sd
Reg: 12-08-08
11-27-19 10:06 AM - Post#2781069
Continuity between hi and low wires? Shouldn't be [of course]
Check for wires touching at light wire connectors, on each side of the rad support.
Disconnect light wires that go thru tube in front of rad, too see if problem is before or after that place.
Adding one headlight wire at a time, may reveal issue.
Jeff1951
Reg: 11-12-18
11-27-19 10:24 AM - Post#2781070
    In response to lobucrod
  • lobucrod Said:
Use a jumper wire to connect the terminals on the dimmer switch plug and see I’m you have separate high and low beams. It so the switch is the problem. If still only high beams you have the high and low circuits I’m the wiring harness shorted together somewhere. If you just wired the switch you may have the hot lead on the wrong terminal
That is a great suggestion and I will give it try.
I'll report back when I do.
Jeff
Jeff1951
Reg: 11-12-18
11-27-19 10:27 AM - Post#2781071
    In response to chevyivar
That I have done and no change. I don't believe that the switch is the problem because I get continuity to the "L" post and when I activate the switch the continuity to this goes away and there is continuity to the "U" post. That would indicate that the switch is switching from one to the other as it should.
Jeff
Jeff1951
Reg: 11-12-18
11-27-19 10:28 AM - Post#2781072
    In response to 53sd
Another good suggestion. Thank you!
Jeff
Jeff1951
Reg: 11-12-18
11-29-19 10:38 AM - Post#2781248
Update- problem solved! It turns outhat the high and low filament on one of the bulbs were touching. A different bulb soved the problem. Thanks again for all your suggestions.
Jeff
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
11-30-19 08:35 AM - Post#2781280
That is a weird one. Good detective work and thanks for letting us know. I like mysteries with a happy ending.
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
Jeff1951
Reg: 11-12-18
12-01-19 06:38 AM - Post#2781327
    In response to mahlmann
What I suspect is that one of the filaments was ready to break and was starting to melt and was drooping down and touched the other. In a very short time it would have broken and gone dead.
Jeff
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
12-01-19 10:14 AM - Post#2781333
When I worked in the sign industry and we were sent out to replace bulbs on a lighted sign with a mover. We would flick the bulbs with our fingers to get the broken filament to fuse back together if we could. It would save the customer a few dollars. But never heard of that happening to a car head light. Interesting.
1951 Fleetline Preservation
Execution time: 0.16 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:26 PM
