Username Post: Global West VS CPP Tubular Control Arms        (Topic#358932)
HYPR
HYPR
Loc: Shaking and Burning!
Reg: 07-19-01
11-25-19 10:28 AM - Post#2780924
Hi guys,
I am trying to get some review/opinions on the upper and lower Tubular Control Arms from Global West VS CPP.
I would prefer to hear from those who have actually owned or are driving their Tri-5 with these. Both appear to be quality products but there is a huge difference in pricing.
Thank you,
Bob
Member #409
11-25-19 01:27 PM - Post#2780935
    In response to HYPR
The Global West arms have had a problem in the past of interfering with a power steering box such as a CPP500 or Borgeson. I don't know if they've addressed this in the more recent past or not.
I do not trust any kind of part from CPP any more.
Consider Heidts.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
11-25-19 04:03 PM - Post#2780943
    In response to Rick_L
FWIW, I have a set of CPP lower control arms on my '57 Chevy. During installation I noticed there was no stop for the steering. This concerned me so I called CPP and was told it was not needed. I felt it was so I welded on my own stops, I did not want the steering to have a chance to go over center. I have a set of Global West A arms (upper and lower), on my Studebaker which has a '68 Camaro front clip on it. I am happy with them and they bolted on without any hassle. I know this is not an exact comparison, but I thought I would pass on what I know. I agree there is a big price difference, but I believe in the quality of the Global West products.
HYPR
HYPR
Reg: 07-19-01
11-26-19 03:59 AM - Post#2780975
    In response to 5Larry7
Thanks for the reply, yes I noticed that neither the Global West or Or CCP have turning stops welded onto the lower arms.
I also looked at the ones sold by Southwest Performance Products also don’t have this either. I suppose this is something I will need to weld on if needed which isn’t a huge deal.
Chevelle
ChevyTalk Community Manager
Chevelle
Loc: Dana Point, CA
Reg: 08-31-13
11-26-19 08:09 AM - Post#2780985
    In response to HYPR
If the comparisons are close please remember that CPP has been a sponsor of the site for many many years.
Don't forget to mention ChevyTalk if you call.
Chevelle
Community Manager
I'll be happy to help just ask.
Click here to become a Gold Supporting Member and we'll turn off the ads at the top!!!
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
11-26-19 01:24 PM - Post#2781010
    In response to HYPR
I went to the Global West website and here is a link to their lower A arms. Check the smaller photos it shows their Adjustable steering stop.
https://www.globalwest.net/1955-1956-1957-chevy- be...
HYPR
HYPR
Reg: 07-19-01
11-27-19 07:06 AM - Post#2781052
My mistake for overlooking that. Thanks Larry!
It also looks like a really simple modification to add to virtually any set of arms. A spacer tapped with threads welded to the lower and a bolt. Just add additional spacers for adjustment. NICE!
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
11-27-19 09:08 AM - Post#2781066
    In response to HYPR
Actually I did a similat thing with my Global West lower A arms on my Camaro front clip. The arms had steering stops, but I wanted a better turning radius. So I cut part of the welded on stop and tapped it so I could put a bolt in there and adjust the turning radius. I got the better turning radius I wanted with no tire rubbing or suspension interference.
HYPR
HYPR
Reg: 07-19-01
11-27-19 11:07 AM - Post#2781080
I spoke with my son who owns a welding and fabrication shop and he suggested that a tab can be made with a capture for a nut. Much simpler and less powder coat removal.
Simple for adjusting just add spacers or shims behind the bolt.
He recommended using a .50” Stainless lock head bolt. This way no lock washer needed. Simply add a rubber stopper over the hex head. Nice and clean.
56_Kruiser
56_Kruiser
Loc: St. Augustine, Fl
Reg: 09-23-05
12-14-19 10:18 AM - Post#2782138
    In response to HYPR
I had put upper arms on convertible back when I first built it back in 1983, to get better range for alignment.. I don't recall the brand. But they did wear out.
So, I replaced them with Global West arms, and wow, what a difference. It drives / handles better than it ever did.
I have a CPP 500 power steering unit and it all works together fine.
1956 Chevy
Vid of 61
61 Chevy
Bruces 57
Reg: 01-03-07
01-02-20 06:39 AM - Post#2783483
    In response to kwhizz
Hello;
I had the CPP upper and lower arms installed on my 57 almost 4 years ago! The person installing these did only front end work and alignments only on Classic Cars.
At the time I added 2" lowering springs. All has been fine. A bit after, I had the same guy ad a CPP 500 box to the mix and that made the car a joy to drive!!!! And to top that, I installed a CPP (5 years in my garage) Sway Bar, in my driveway and that works wonderful as well!!!
Since I had body and paint and interior, I have not driven the car much but don't seem to have any issues of any kind so far!
Recently, I installed a complete Willwood disc brake system and that has yet to work like I think it should, but I do have brakes but the problem lies in the fact that the rear calipers I got (Caddy Seville) have yet to be adjusted or properly shimmed correctly. Im no brake expert so I guess I gotta find someone that knows the secrets of how the heck these calipers adjusted as well as my emergency brake adjustments!!!!! (everything new, even the ss brake lines!!)
Bruce
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
01-02-20 07:15 AM - Post#2783487
    In response to Bruces 57
I also installed the Caddy rear disc brakes on my '57. I also had some difficulty getting them to work correctly, but with the help of a tech guy at Right Stuff Detailing, they now work fine. One thing you may already know, is to use the parking brake pretty much every time you drive the car. That action keeps the brakes adjusted and working right. Also proper bleeding is necessary. I suggest you call Right Stuff Detailing and talk to their tech man. Here are a couple of links that might be of help: https://classicbroncos.com/reardiscs.shtml
Also Google: Installing Cadillac El Dorado rear disc brakes on a classic car. lots of info there. in particular: https://www.youtube.com/watch?v=opjdu8DdVeA Good luck, Larry
Edited by 5Larry7 on 01-02-20 07:24 AM. Reason for edit: No reason given.
Execution time: 0.197 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:28 PM
