Username Post: Drivers window felt.        (Topic#358929)
probelair
Reg: 11-01-19
11-25-19 06:59 AM - Post#2780908
The felt strip moves up and down with the window. How do i properly repair this. Thanks in advance.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
11-25-19 07:45 AM - Post#2780911
    In response to probelair
You secure it to the door frame.
probelair
Reg: 11-01-19
11-25-19 08:26 AM - Post#2780914
    In response to Tri5man
With what may i ask.
I havent bought a restoration manual yet. Thanks.
omarine
omarine
Loc: San Diego
Reg: 06-29-15
11-25-19 09:28 AM - Post#2780920
that felt strip slides up and down, but it's meant to be a tight fit - no hardware required. try to see if you can pull the old one up and out. then place new one in and push down on it while it slides down into place. go slow, you'll see it's fairly simple.
cheers
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
11-25-19 11:17 AM - Post#2780928
are you talking about the chrome beaded track on the vent window assembly ? If so the original rivets are replaced with screws and hex nuts (you have to drill holes in the chrome beaded track to match the original holes....)
I have pictures of this installation..
The rear felt track by the door jamb is held in place by glueing it to the track with 3M spray glue.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
pvs409
pvs409
Reg: 01-10-05
11-25-19 11:18 AM - Post#2780929
    In response to pvs409
I am talking about 2 door hardtop vent frames not 2 door sedan...
probelair
Reg: 11-01-19
11-25-19 11:47 AM - Post#2780931
Its the track that butts up against the wing window.
Was riveted i was told. Can it be used with a tiny screw or do i need a new one?
junky
Loc: Northeast CT
Reg: 06-27-10
11-25-19 04:27 PM - Post#2780946
I would purchase a new liner from Restoration Specialties in PA. I glued mine in using a couple dabs of epoxy. I placed some paint stirring sticks into the felt and then using tie raps (commonly called zip ties) I tightened it up till the epoxy dried. That was 20 years ago, and they still haven't moved.
probelair
Reg: 11-01-19
11-26-19 03:52 AM - Post#2780974
    In response to junky
Any particular type of epoxy/glue to hold the felt track in place?
pvs409
pvs409
Reg: 01-10-05
11-26-19 12:34 PM - Post#2781005
Having done 8 vent window restorations in the last 10 years and currently doing 2 more for friends, I would "not glue" in the u shaped felt strips.
What year 61 to 64 do you have and is a Impala ?
Paul
probelair
Reg: 11-01-19
11-26-19 06:16 PM - Post#2781028
Its a 61 impala Bubble Top.
It looks like there are dabs of glue marks on it now.
pvs409
pvs409
Reg: 01-10-05
11-26-19 09:36 PM - Post#2781038
Pictures will be posted Wednesday of vent window restoration like your 61.
56_Kruiser
56_Kruiser
Loc: St. Augustine, Fl
Reg: 09-23-05
11-27-19 10:49 AM - Post#2781075
I'll be interested to see too. I'm updating one of mine now.
I had used silicone. It seemed to hold them fine (not sure it's needed based on the comment above). Wasn't difficult to pull them. Took a few minutes to clean it out for the new install.
1956 Chevy
Vid of 61
61 Chevy
pvs409
pvs409
Reg: 01-10-05
11-27-19 04:48 PM - Post#2781111
    In response to 56_Kruiser
Attached are pictures of most of the vent window restoration.
1. the first picture shows all the parts to restore the vent windows -the chrome bead is already installed on the vertical tracks in this picture. The condition of your vent window rubbers and the vertical rubber is also something to consider (watch for junk repro rubber parts that do not fit...)
2.the remaining pictures show details of the original rivets on the vent vertical tracks the screws and nuts to replace the rivets.
3 Note that the original chrome bead had 2 square holes (in the pictures )were the vent rubber tabs where installed and bent over in the felt.
4. Note that the chrome bead was originally cut at a angle to match the chrome strips on the vertical tracks.
5.Also you may need new upper Division bar rubber covered stops -at the top of the chrome beaded felt
See the next post for more information on the screws to use 6/32 inch stainless screw and stainless nuts
Paul
Attachment: IMG_0024.JPG (137.6 KB) 3 View(s)
61 and 62 Chevy all the restoration parts to restore the vents
Attachment: IMG_0023-006.JPG (120.21 KB) 2 View(s)
Original 61 and 62 vent assembly with riveted chrome beaded channel - removed 2 piece factory channel in the picture
Attachment: DSCN7730.JPG (160.87 KB) 3 View(s)
Factory rivets(2 of them) that hold the chrome frames to the vertical channel and one rivet that holds the channel below the chrome vent frame -one more rivet hold the channel-not in the picture at the bottom of the vertical channel
Attachment: P1010074.JPG (209.41 KB) 3 View(s)
Picture of the chrome beaded C shaped vent vertical track to replace the original 2 piece track
Attachment: IMG_0027.JPG (122.21 KB) 2 View(s)
back side of the vertical tracks with the screws installed in place of the rivets - chrome window frames not installed in this picture
pvs409
pvs409
Reg: 01-10-05
11-27-19 05:07 PM - Post#2781114
more pictures attached of the screws to install the chrome beaded channel.
rubber covered stops at the top of the channel(held in place with small philips screws) are not shown in these pictures. Do not cross tread the small screws at the top of the channel -the treads in the pot metal chrome frames can be ruined if you cross tread the tapped chrome channels.
Attachment: IMG_0031-006.JPG (104.79 KB) 2 View(s)
original flat headed rivet from vent vertical channel and the stainless 6/32 screw to replace the rivets
Attachment: IMG_0033-005.JPG (117.63 KB) 2 View(s)
two sizes of 6/32 stainless screws, nuts and lock washers to replace the factory rivets
Attachment: IMG_0034-005.JPG (119.88 KB) 2 View(s)
picture of the stainless 6/32 screws and hex nuts -purchased from Menards -I use both sizes. 4 screws are needed per vertical channel + the two tabs at the top of the channel that have to be bent over
Attachment: IMG_0038-008.JPG (114.63 KB) 2 View(s)
picture of the tab locations on the channel that have to be bent over to hold straight channel rubber seal to the channel -top two tabs have to be drilled through the chrome beaded channel and/or add glue to hold only the upper (last 3 inches ) part of the chrome beaded channel
Attachment: IMG_0037-009.JPG (95.62 KB) 3 View(s)
Picture of the chrome beaded channel cut at a angle to fit the chrome strips and the angled channel itself -to match the factory cut channel
pvs409
pvs409
Reg: 01-10-05
11-27-19 05:25 PM - Post#2781116
here is the chrome beaded channel that I use -36 inches long for each piece to fit correctly on the vertical factory vent tracks. For 58 to 62
https://show-cars.com/product/3407
For 63 & 64
https://show-cars.com/product/3405
Paul
Execution time: 0.264 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:30 PM
