Username Post: 63 non-tilt steering column turn signal switch and upper bearing replacemen        (Topic#358844)
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
11-17-19 12:45 PM - Post#2780365
Project car came with original Bel Air steering column (from the gear box up) plus a new Ididit tilt kit - both in a box in the trunk. I'm in the process of rebuilding the original assembly for re-installation (if interested in the Ididit please PM me) and the 63 shop manual is not a lot of help to me, esp for the turn signal switch replacement. Any references for these procedures will be appreciated.
Incidentally column is being rebuilt for floor shift - tube is being retained but shifter ears and shift lever mounting "stub" have been cut off and the stub filled and finished - so proper operation/adjustment of the shifter is no longer a necessity. Upper and lower bearings and TS switch are new. An, issue, so far, is that it seems the upper bearing horn ring does not want to fully seat. Appreciate any help that you guys can pass on.
Regards,
PS Just realized that I have an Argo horn ring installation kit (PN 57C 3626) that fits 57 Chev (all models) and 63 Chev Impala only, so it seems I have the wrong kit. Any recommendations?
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
11-19-19 01:48 AM - Post#2780477
    In response to Highlander1
The 63 switch is unique to 63 bra.
Do you have an assembly manual, I think there is a good drawing of all the components of the 63 steering column. I do not have a 63 assembly manual, haven’t been able to find one for my Parisienne, which has a 63 Chev column. Not sure if any drawings in the 63 shop manual supplement?
Member #2194
DonSSDD
DonSSDD
Reg: 08-21-01
11-19-19 02:04 AM - Post#2780479
    In response to DonSSDD
There is a pic of the 4 speed column in that thread that may be of some help.
Member #2194
Execution time: 0.157 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:02 PM
