Username Post: 1964 impala trunk lock        (Topic#358818)
basstracker
Reg: 11-09-18
11-14-19 06:36 PM - Post#2780181
can some one tell me how to put the clip on the lock. i don't see how to get to it. thanks
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
11-14-19 09:48 PM - Post#2780195
    In response to basstracker
The push on vertical c shaped clip should be screwed to the flat area behind the trunk lip.
Remove 2 screws and pry the clip to remove it from the lock cylinder.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
basstracker
Reg: 11-09-18
11-17-19 12:02 PM - Post#2780362
    In response to pvs409
my car didn't have a lock so i got one from rock auto. i can see the two screw holes your talking about but the clip they sent don't have screw holes it just slips behind the lock. the problem is i can't find away to get it on the lock.its to short to put it in the slot and push it on.
pvs409
pvs409
Reg: 01-10-05
11-17-19 12:18 PM - Post#2780363
reproduction junk does not fit, you have to have original parts -from what I have seen.
I have original trunk locks with a long rod to fit into the trunk lock/latch slot and the push in clips that are held in place by screws.
Not sure if my 62's will fit 64's
Paul
basstracker
Reg: 11-09-18
11-17-19 05:57 PM - Post#2780397
would you sell just the clip or the lock and all? what are you asking.
pvs409
pvs409
Reg: 01-10-05
11-17-19 11:00 PM - Post#2780411
check out these pictures compared to what you have.
These are from a 62 but the taper on the slide on clip should fit a 64 trunk.The pictures show 2 mounting clips that slide onto the lock -all so you can see the correct mounting.
Paul
Attachment: IMG_0019-009.JPG (92.36 KB) 3 View(s)
two mounting clips that slide onto the trunk lock
Attachment: IMG_0018-010.JPG (88.07 KB) 2 View(s)
shows how the clip slides over the trunk lock with the long rod that goes to the trunk latch
basstracker
Reg: 11-09-18
11-18-19 09:02 AM - Post#2780431
i think that will work. what will you take for one.
pvs409
pvs409
Reg: 01-10-05
11-18-19 12:45 PM - Post#2780440
See the private message I sent to you.
Paul
Execution time: 0.102 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:36 PM
