Username Post: Richmond 5 speed        (Topic#358798)
lavin
Reg: 08-08-19
11-12-19 03:05 PM - Post#2780062
Do you have to modify the trans tunnel to fit a Richmond 5 speed in a tri-five. I understand the shifter hole is in a different location, but does the tunnel have to be widened? Thanks
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
11-12-19 04:36 PM - Post#2780068
    In response to lavin
You need to talk directly with 2Loose here on CT; he's had a Richmond 5 speed in one of his Tri-Fives, and he just may even convince you it's not the way to go (parts availability). Might also go over to JalopyJournal.Com/the HAMB, in the classifieds; I believe there's a Richmond 5 speed in the classifieds there. Or, it might have been the Seattle area Craig's List. I lose track of so much stuff that's available out there, but I only concern myself with stuff that interests ME.
I am Butch/56sedandelivery.
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
11-19-19 01:35 PM - Post#2780534
Check Summitt's listing for 5 spds. I'm sure I saw a OD 5 Spd. there that does not require anything special as it is to replace a stock Muncie trans.
It's all good. mostly
Execution time: 0.068 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:37 AM
