Username Post: Need a recommendation for a good coil spring compressor        (Topic#358736)
LSS1333
Reg: 05-13-15
11-07-19 01:25 PM - Post#2779735
What is the best (safe) coil spring suppressor for someone who has never used one?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-07-19 02:57 PM - Post#2779741
    In response to LSS1333
https://www.harborfreight.com/single-action-strut-...
about the least expensive option that Ive used that worked reasonably well
above
if your going to do the job every few months
get something a bit more substantial
https://www.youtube.com/results?search_query= 3+ton...
https://www.ebay.com/itm/Spring-Compressor -Hydraul...
Edited by grumpyvette on 11-07-19 02:58 PM. Reason for edit: No reason given.
Member #409
11-07-19 07:08 PM - Post#2779753
    In response to grumpyvette
The best compressor for the job - or even one that will work - is dependent on what vehicle you are working on.
Example, that HF compressor won't work on many cars, but works fine on a few.
Frank_T
Loc: PA
Reg: 12-02-02
11-30-19 05:46 AM - Post#2781273
Ive never had success with ANY coil spring compressor. I havent used all of them, so there may be something that works for you... but I have found a much safer way to compress the spring... Have them Banded. Find a front end shop that does larger trucks and ask to have the springs banded. Basically they compress the spring and put a steel band on it. You can get one or two bands put on them. Normally I get a single band, it looks like a potato chip when you get it but it works fine. Once you get the spring in place and weight of the car on it, just cut the band.
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
11-30-19 04:56 PM - Post#2781308
I rented a spring compressor from Autozone. It is actually free, you just pay a deposit and get it back. I used it on my 62 factory AC Impala SS with stock HD front springs. Changing the front springs is not an easy job, but it worked.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
11-30-19 11:35 PM - Post#2781319
It's kind of late to be chiming in, but the only compressor that I've had good success with are the Ken-Tool compressors for MacPherson struts.
https://www.kentool.com/product/macpherson-st rut-c...
What makes these better than cheap compressors is the screws are Acme threaded. They take axial force better than a conventional "V" thread. The compressors don't have the tendency to wrap itself around the spring when you're tightening the screws.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
12-01-19 01:09 PM - Post#2781339
I have tried some spring compressors, but the one I have the best result using a long piece of threaded rod with an eye bolt on one end and through the eyebolt I put a shock absorber bottom attachment that I took out of an old shock. Then attach the eyebolt end with the old shock part to the A frame through the spring and then through the upper shock mount with a solid washer. Then turn the nut on the upper end of the treaded rod until the spring is compressed enough to get the ball joint into the spindle. Occasionally I have had to disconnect the inner pivot points of the lower A frame, then compress the spring, attach the lower ball joint to the spindle, then re-connect the A frame to the inner pivot points.
Attachment: spring_compressor.jpg (273.26 KB) 9 View(s)
Execution time: 0.312 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:08 AM
