Username Post: 99 k1500, want to install bigger tires        (Topic#358730)
93 low
Reg: 12-06-11
11-06-19 07:32 PM - Post#2779698
99 K1500, extended cab, 5.7 Vortec, auto trans, (GMT 400) Fabtech 6" lift, 6 lug rims says "4x4" on rims. I have BFG A/T 265/75/R16 tires on now that need to be replaced. I'm using my same rims. How big of a tire can I run without having to replace or change any speed sensors, solenoids, modulators, etc?
Thank you for your time.
2plus2
Loc: Mission,BC
Reg: 02-03-05
11-06-19 08:10 PM - Post#2779700
    In response to 93 low
What gears do you have now? This kinda determines what to size to go with
Do you plan on offroading it?
A 6inch lift will fit a 315/75r16 or a 35x12.5 on a 8 inch wide rim
69 Canadian Pontiac 2+2
MiragePilot
Loc: Tucson, AZ
Reg: 08-18-16
11-07-19 11:12 AM - Post#2779729
    In response to 2plus2
The previous owner of my 2002 Express van put oversized rims and tires on it such that the tire diameter was about 11% larger than OEM. This resulted in an 11% error in the indicated speed and odometer/trip readings, and messed up the engine/vehicle gear change speeds. I don't like it at all!
As soon as these tires are due to the be replaced I will be putting new tires on that gets the tire diameter back to the OEM size.
So, to answer the original question, I would not recommend increasing the tire diameter anywhere near 10% larger than the OEM diameter, but that is just my opinion.
Peter
2002 Chevy Express 1500 conversion van (Explorer SE conversion)
RIP (totaled in Feb '18): 1996 Chevy Express 1500 conversion van (Starcraft Hi-Top Conversion)
93 low
Reg: 12-06-11
11-08-19 07:33 PM - Post#2779808
2plus2,
I have no idea what gears are in the truck. I don't do any major off roading or rock crawling. I often tow a bass boat and/or use the 4 wheel drive when in the mountains driving in the snow.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-08-19 10:43 PM - Post#2779816
You should have a list of options in your glove box if the label is still readable. Look for one of the following codes: GU4, GU6, or GT4. The ratios are 3.08, 3.42, or 3.73. You might on the odd chance see a GT5 4.10, but that’s not all that common on a stock K1500.
Greg
'00 Explorer XLT 4.0 V6 Auto
11-09-19 10:21 AM - Post#2779839
remember that a taller tire will reduce your braking power. i dont know the numbers its physics
Execution time: 0.13 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:26 PM
