Username Post: Blower fan not working        (Topic#358720)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
11-05-19 02:33 PM - Post#2779617
Anyone know how to get the blower fan to work?
Chair City
Chair City
Loc: Thomasville, NC USA
Reg: 01-24-04
11-05-19 02:40 PM - Post#2779618
    In response to Eth727
Do you have 12 volts at the blower terminal? If not check the fuse.
1960 Impala Spt. Cpe. Now in my son's garage
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
11-05-19 04:22 PM - Post#2779629
    In response to Chair City
No
Chair City
Chair City
Reg: 01-24-04
11-06-19 12:04 PM - Post#2779679
Check for 12 volts at both ends of heater fuse with ign. switch on
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
11-12-19 11:54 AM - Post#2780046
There's no power going to the heater fuse.
Chair City
Chair City
Reg: 01-24-04
11-12-19 02:39 PM - Post#2780061
Does everything else work,lights,horn,signals? Will engine start and run?
ragtp66
ragtp66
Reg: 12-09-07
11-12-19 06:03 PM - Post#2780073
Quick test runner a jumper from battery Positive to the stud where the power wire connect if it does not go then your motor is kaput or possible just stuck. Pull it off the car and see if you can turn it by hand. Sometimes they will just surface rust from condensation and sitting and all it takes is working it free by hand and then try it again.
Toys:
1987 Sea Ray Pachanga 22
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
11-12-19 11:22 PM - Post#2780087
    In response to ragtp66
Yeah I ran a cable straight from BATT to the blower and it worked. I followed the brown wire to bulkhead connector, opened it and found dirt. Cleaned it out and got the fan working again thanks.
Execution time: 0.112 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:01 PM
