Username Post: where should I tie a volt gauge in ?        (Topic#358705)
VanLife
Reg: 03-20-18
11-04-19 02:40 PM - Post#2779541
are there any reasonably priced gauges that will show real time voltage and amperage being put out by the alternator??
Do I connect it at battery or off the back of alternator?
The following is why I want to see what my system is actually doing real time.
I am looking at installing a "smart" DC to DC 40-50amp charger/ 1000watt sinewave power converter.
To add amperage boost of 30 to 50 amps at 14.3 volts to the x2power battery I have. to shorten the overall time my engine needs to be running to fully charge the battery from depleted state.
My current factory setup is unable to charge a starter/deep cycle battery fully in any meaningful short period of time.
How do you tell the alternator, that it needs to put out x amount of amps to power this assesory dc to dc charging device, or will it increase the amps when it detects the draw off the alternator?
I currently have an AC 100-110 amp alternator in there in place of the NON-AC 80-85 amp alternator, so I have an extra 20-30 amps regular load draw. Also removed the radio so that won't be drawing power.
The x2power battery I currently have has a reserve of 25amp draw for 122 minutes. Equivalent of a 68AH battery I think.
I was told I can put a higher amperage on this battery, because of its solid core AGM, where the post is solid rod that goes through the core instead of thin wires attaching the post to the battery internally.
It also does like 810 cca.
when asking Questions its related to van I own: 1987 GMC 3/4 ton G2500 vandura, V6, No AC, standard length. 3speed trans(no overdrive).
rumrumm
"19th Year" Silver Supporting Member
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
11-05-19 10:20 AM - Post#2779592
    In response to VanLife
To answer one of your questions: you do not hook a voltmeter to a 12V source. You want to find a source that is only hot when the ignition is switched on.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, FiTECH. Dyno #'s: 450 hp @ 5700, 468 lb. ft. of torque @ 4300.
65_Impala
Reg: 12-29-02
11-05-19 02:25 PM - Post#2779612
Here are a couple of ideas for meters.
https://www.amazon.ca/Electricity-Monitor-6- 5-100V...
https://www.amazon.ca/DROK-Multimeter-Voltme ter-Ca...
The first one is pretty simple. I would fuse or put fusible links on the 2 wires from the shunt to the meter. Power the meter from a switched ignition source.
The second one is more complex and has that short white jumper to go between the sensor and meter. So, likely not much good to put inside a vehicle unless you loop the charging wire into the cabin. It does have the ability to operate a relay depending on the protection settings. You can use that relay to turn a device off or power a light or something else.
There are others too, just look for something you like. Just make sure it's for DC, not AC.
As for the alternator, it just tries to maintain the output voltage, so it produces whatever current is required to do so until it reaches it's maximum current limit. Don't forget, the alternator may be 110A rated but that is not the output at idle, and likely not when it's hot either. Engine likely has to be turning about 2000-2500rpm to get full alternator output.
Another thing to check is the voltage sensing wire for your alternator. This is the terminal where it senses the voltage feedback. If you run the wire to the battery it'll try to regulate the voltage at the battery, not at the wiring harness or the output stud of the alternator. This will automatically compensate for any wiring resistance.
11-06-19 08:26 AM - Post#2779660
I'm not sure you can create power. Any power the "smart converter" puts out has to come from someplace, either the alternator or battery.
11-06-19 10:01 AM - Post#2779671
    In response to acardon
Are components different to measure voltage vs amps? I'm curious since my truck with a 165 amp alternator has blown two digital voltage gauges. I'm thinking to converting to amps instead of voltage.
'08 GMC Acadia 3.6L SLE
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-07-19 12:21 AM - Post#2779711
Yes, G, the two meters are different. The reason that auto manufacturers switched from ammeters to volt meters was due to the switch from generators to alternators. The high current death nell of a failing generator was able to be foretold by a spike in generator current. The change to alternators, which have better cooling features and voltage regulation, made installing a volt meter the better choice.
Ammeters are generally more expensive than volt meters and can be installed with much smaller wiring. The digital gauges may have sub standard internal parts. Not certain, just speculating.
Having said that, the emergence of less expensive Hall effect current transducers has made having a 300A class DC ammeter very economical. I see they’re available for under $50.
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-07-19 01:30 PM - Post#2779732
If I may jump in here for a little?
One of the big drawbacks to the ammeter was the fact that ALL of the juice had to go through the ammeter. If you had a loose nut, or a terminal was corroded it caused a lot of overheating. The terminals were barely large enough as it was. (I have seen some newer stereo units that had larger wires than were run through the ammeter!)
I have had a lot of the insulators melt out of the little bracket that held it in the dash. Now we are talking about a direct short to ground. You now have an 8-10 ga wire melting all the way to the voltage regulator. NOT FUN!!
I would just stick to the voltmeter. very small wire, simple hook up. Just tap into the ignition, ACC terminal of your switch.
This was only my two cents. Feel free to ignore.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
11-07-19 09:15 PM - Post#2779757
    In response to beagrizzly
If you look at the examples given for a large current ammeter, there is a shunt that ALL the voltage goes through and it uses small wires to measure the voltage drop across the shunt in the engine compartment, and calibrates it to read in amps.
The problem with that is, the shunt does cause a voltage drop, although small, so it's defeating the problem your trying to overcome. Again, you can't create energy with your inverter/converter. That energy comes from the alternator.
Edited by acardon on 11-07-19 09:16 PM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
11-08-19 10:25 PM - Post#2779814
GM ammeters measured voltage across a section of the charging wire so voltage drop across the shunt doesn't need to be a concern.
11-09-19 08:25 AM - Post#2779832
    In response to 65_Impala
There HAS to be a voltage drop or there won't be any thing to measure. The wire has to be sized and the correct length between the ammeter leads to provide a voltage drop to calibrate the meter to. The wire is the shunt.
The original poster doesn't have a GM meter.
11-09-19 11:27 PM - Post#2779877
i run my ampmeter after all junctions so that the only thing it sees is the battery. the only amps flowing through it go to the battery. that way i know if the battery is getting charged or not. along with a voltmeter i get a good look at what the system is doing. 1st gen obd.
65_Impala
Reg: 12-29-02
11-10-19 01:59 PM - Post#2779912
It's just a piece of 10 gauge wire same size as cars without an ammeter. Probably about 4-5' of wire and there was no extra wire compared to a car without an ammeter. So, it adds no extra voltage drop compared to cars without ammeters.
You can get an ammeter that uses a shunt to wire it similar to what GM did.
And the OP doesn't seem to have any ammeter.
Execution time: 0.109 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:23 AM
