Username Post: Powerglide question        (Topic#358698)
Marcus
Loc: San Diego, California
Reg: 02-19-01
11-04-19 12:10 AM - Post#2779504
So I'm having a problem adjusting the column shifter on my 63 impala and would like to bypass the stock linkage with a cable style system but still retain the column shifter. Is there anywhere that sells such a conversion kit.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
11-04-19 06:41 AM - Post#2779518
    In response to Marcus
Not sure if they have anything are not for the 63. They have them for the 64 and you might could make it work on the 63. I' call and speak to them.
Shiftworks:
https://shiftworks.com/collections/impala-pr oducts
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
junky
Loc: Northeast CT
Reg: 06-27-10
11-04-19 06:52 AM - Post#2779520
If you follow the instructions in the factory service manual, step by step, it is extremely easy, and precise. Now, if you are inclined to try to reinvent the wheel or create a better mouse trap, it might not be as easy as following the instructions in the manual.
impala62
Loc: The Netherlands
Reg: 04-02-07
11-04-19 10:24 PM - Post#2779569
    In response to junky
My first step would be, check and / or replace all the bushings in the linkage.
Also check your motor mounts and powerglide mount.
If all are in order everything should work fine.
Had the same problem on my 62, also concidered a cable but dicided to do it the origional way.
62 327 4 door hardtop
Marcus
Reg: 02-19-01
11-05-19 08:38 AM - Post#2779589
    In response to impala62
It seems to not want to stay in park regardless of how I adjust it...worried about it slipping into reverse. I did think that maybe the motor/ trans mounts are so worn that it's putting everything out of alignment. Makes sense. I'd rather do it properly ideally. I'll crawl under and check it out today.
impala62
Reg: 04-02-07
11-05-19 09:25 AM - Post#2779594
when under the car also check the bushings in the shift linkage.(hinge point)
Mine were completely missing
Lots of free play in linkage and not staying in park.
Also indicator was way off.
junky
Loc: Northeast CT
Reg: 06-27-10
11-05-19 12:01 PM - Post#2779607
I had the same problem with my car, and it turned out to be the steering column was out of alignment. Once the column was properly adjusted, and the Powerglide adjustments were made, no more jumping out of park.
Marcus
Reg: 02-19-01
11-06-19 12:42 AM - Post#2779647
Interesting, how was your column out of adjustment? I do have a lot of slop in the linkage although even when I manually put the trans in park it just doesn't seem as positive as the th350s I'm used to. This is the first glide I've dealt with.
Marcus
Reg: 02-19-01
11-06-19 12:50 AM - Post#2779648
Junky, where do I get a service manual for my 63? I think you're right in following the factory directions in this case.
junky
Loc: Northeast CT
Reg: 06-27-10
11-06-19 03:07 PM - Post#2779683
You are going to need the 1962 Chevrolet Shop Manual, and the 1963 Chevrolet shop manual supplement. I suggest that you look on ebay, and buy the least expensive one available. If you use it, it is going to get dirty, and a new one will look just like the lesser priced ones, in just a few weeks of use. You can also find them online, https://www.dropbox.com/sh/e6y4bdp4z7oagvr/AA BbRH1...
Make sure to only purchase original or reproduction manuals. The Hayes, etc., won't be of much help, since they are generic..
I adjusted my column by the nuts on the threaded rod that holds the column up. Mine was off to the right side, and too high.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
11-06-19 05:21 PM - Post#2779691
It’s the 61 shop manual you need and the 63 supplement, the main manual is the 61. The 62 manual is a supplement to the 61, not needed for the 63. Junk had some brain gas.
Member #2194
junky
Loc: Northeast CT
Reg: 06-27-10
11-06-19 09:34 PM - Post#2779709
    In response to DonSSDD
Someday you will be old like me, dealing with complex issues without resolution.
Marcus
Reg: 02-19-01
11-06-19 11:57 PM - Post#2779712
Good to know...think this will be a good investment in the long run thx
DonSSDD
DonSSDD
Reg: 08-21-01
11-07-19 08:28 AM - Post#2779725
I think we are pretty close in age Junk , I’ll be married 45 years on my next anniversary. I get plenty of brain gas too.
Member #2194
Marcus
Reg: 02-19-01
11-09-19 10:57 PM - Post#2779878
So I examined the linkage closer and realized the swivel linkage connecting the column to the adjustable rod was extremely loose. So I tightened it up so there is zero slop now...improved it 100 %. I am able to shift all gears including park with the indicator accurately pointing to the corresponding gear.
junky
Loc: Northeast CT
Reg: 06-27-10
11-10-19 02:45 PM - Post#2779921
Thanks for the response telling us what you found, and how you corrected it. This goes a long way to helping others, when they do a search looking for answers to problems. There will come a day when all us old timers will have lost our memory and won't be able to help, but our posts will live on for eternity on these forums.
Marcus
Reg: 02-19-01
11-11-19 01:40 AM - Post#2779952
And without the knowledge and experience on this forum I might have wasted money on a aftermarket part, to what turned out to be a relatively simple fix of the original equipment.
Execution time: 0.614 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:03 AM
