Username Post: "Okie bushing" drive shaft bushing instal        (Topic#358690)
64chevyclassic
64chevyclassic
Loc: Moorpark Ca
Reg: 01-09-13
11-02-19 08:16 PM - Post#2779409
I found it pretty straightforward on getting the old drive shaft bushing out prepared to install new okie bushing. Using wood block and hammer to drive it in but does not seem to want to go in? Even heated up the torque tube to see if it would go in but no different. What can I check or do to make driving this in possible?
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
11-04-19 01:19 AM - Post#2779506
    In response to 64chevyclassic
Put the bushing in the freezer for several hours?
I am Butch/56sedandelivery
Mick53
Mick53
Loc: Northern Indiana
Reg: 04-02-16
11-04-19 05:43 PM - Post#2779549
I use dry ice -109f
64chevyclassic
64chevyclassic
Loc: Moorpark Ca
Reg: 01-09-13
11-07-19 02:36 PM - Post#2779738
Great idea thank you for the help. I remeasured the bushing and torque tube looks like it was to big to start with called jim Carter and exchanged the part for the correct size bushing should be here today I hope. I'll update when finished thanks again!
64chevyclassic
64chevyclassic
Loc: Moorpark Ca
Reg: 01-09-13
11-13-19 11:48 AM - Post#2780107
    In response to Mick53
Got the correct okie bushing and when to town on it yesterday with some home run sledgehammer swings got it all the way in! Got it up in the air on 4 jack stands to avoid rolling . De bured spline with fine sand paper and was very happy with the results.
Execution time: 0.132 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:05 PM
