Username Post: 6cylinder radiator position        (Topic#358677)
rls8836
rls8836
Loc: North La.
Reg: 01-30-02
11-02-19 09:46 AM - Post#2779366
Where is the 6 cylinder position?
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
11-02-19 10:48 AM - Post#2779370
    In response to rls8836
6 cylinder radiator mounts in front of the radiator support; V-8 position the radiator mounts behind the radiator support. I am Butch/56sedandelivery.
rls8836
rls8836
Loc: North La.
Reg: 01-30-02
11-02-19 06:37 PM - Post#2779404
Thank you
Mel Foye
Mel Foye
Reg: 09-29-00
11-03-19 12:52 PM - Post#2779456
While there was no question on WHY it is because the 6 is longer than the v8 so the radiator was moved forward.
streets
streets
Loc: Central Illinois
Reg: 05-30-04
02-29-20 07:08 PM - Post#2787637
    In response to Mel Foye
Hi Guy's
glad you posted this. I didn't want to start a new topic when this is in a recent archive. Hope this post is seen and replied to as the topic is a few months old.
Just finishing up on my son's 56 2-dr Handymen.
The stock radiator finally bit the bullet, We purchased a new aluminum one and it doesn't want to sit down low enough to clear the hood. The car was originally a 6 cyl. You see a 350 in it now.
We are planning to buy a new core support.
The question is: Will we wind up with the same issue buying an 8 cyl. core support?
The replacement radiator is exactly the same dimensions as the one that came out and it cleared the hood.
Thanks!
Attachment: Brans_56_Radiator_side.jpg (3.27 MB) 5 View(s)
Attachment: Bryans_56_Front_Radiator.jpg (3.05 MB) 4 View(s)
02-29-20 08:03 PM - Post#2787641
    In response to streets
That doesn't look like a 6 cyl radiator. The mounting brackets on a 6 cyl radiator point toward the engine/rear. Those brackets are pointing forward. You do need a new complete core support. That one has been cut so there is nothing to hold them fender in alignment. You don't have room for a 8 cylinder support with that radiator in the 8 cyl position.
Edited by acardon on 02-29-20 08:06 PM. Reason for edit: No reason given.
streets
streets
Reg: 05-30-04
03-01-20 09:04 PM - Post#2787730
    In response to acardon
Thanks for looking at this. You are correct, This is a new 8 cylinder Aluminum radiator. We will buy a new
8 cyl. CS (Core Support.)
I also learned you can buy a replacement bar for about the same price.
Would you say the "cut core support" in it is a 6 cylinder?
And
Without having 6 & 8 cylinder core supports side by side to compare,
What difference in the core support frame(s) would you see if you did have both to compare?
IOW
Would the 8 cylinder CS mounting brackets (facing forward) move the 8 cylinder radiator
to approx. where it is at now, but also pull it down to clear the hood?
streets
streets
Reg: 05-30-04
03-01-20 09:27 PM - Post#2787734
I think I understand now.
In the V-8 position, the radiator is behind the top bar if there were one.
R&R the radiator mounting brackets to the inside of the core support.
Sound Right?
What was throwing me was Vendors sell 6 & 8 cyl. core supports.
Attachment: 56_Rad_CS_Position.pdf (345.54 KB) 8 View(s)
03-02-20 07:44 AM - Post#2787760
Sound Right?
Yes, a V-8 support has the mounting brackets for the radiator on the engine side of the top bar. A 6 cyl has them on the grill side of the top bar, which puts the radiator in front of the bar instead of behind the bar. It doesn't look like you will have enough room for the radiator on the engine side, with your alternator mounting bracket.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
03-02-20 08:48 AM - Post#2787764
It's hard to tell from the picture, but it looks like you got the long water pump on it, so you wouldn't have enough room to mount the radiator in the V/8 position.
streets
streets
Reg: 05-30-04
03-02-20 08:07 PM - Post#2787827
    In response to 55 Shaker
Thanks a lot guys. It isn't running a fan blade, (electric) so I thought there would be enough room.
Good eye on the alternator/bracket and water pump length. Easy fix.
V-8 core support should be here soon.
Execution time: 0.157 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:49 AM
