Username Post: Trans X member mounting problem        (Topic#358656)
tikiwagon
tikiwagon
Loc: dorset, england
Reg: 04-23-04
10-31-19 11:28 AM - Post#2779225
Hi I have a 59 which i have converted to a 200r4 Overdrive trans, I bought a crossmember from Bowtie overdrives and not sure what way up it mounts and what holes in the frame do i use(upper or lower)Please see attached pics
https://i1073.photobucket.com/albums/w391/tikiwago...
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
10-31-19 01:06 PM - Post#2779234
    In response to tikiwagon
If it mounts like the one for a 700r4 your first picture is the way it should be.
58 Delray in disaray
tikiwagon
tikiwagon
Reg: 04-23-04
11-01-19 09:12 AM - Post#2779297
    In response to Techhead
Thanks for that so what hole should i mount it in(upper or lower)It looks like it fits better the other way up to this pic too
killerkjn
Loc: Edgewood, WA, usa
Reg: 12-19-02
11-02-19 04:24 PM - Post#2779399
I just finished a 2004r swap in my 62 impala. I used the top holes and still needed a couple of shims to get the driveline angles correct and I used the same cross member as you.
tikiwagon
tikiwagon
Reg: 04-23-04
11-04-19 12:19 AM - Post#2779505
    In response to killerkjn
Thanks for that what way way up did you mount it?(please see my pictures)
killerkjn
Reg: 12-19-02
11-04-19 11:30 AM - Post#2779529
Mine mounted like your 2nd picture. Also the holes that mount on the transmission rubber mount didn’t quit line up so I had to file the slot a little longer.
tikiwagon
tikiwagon
Reg: 04-23-04
11-04-19 02:14 PM - Post#2779544
Great thanks for that, I tried that way first of all but looks like it will work both ways
killerkjn
Reg: 12-19-02
11-04-19 06:01 PM - Post#2779551
You will love the powerglide to 2004r swap. It has been the best mod I’ve made to my 62. I have a 283 with a Rochester 2gc carb. I did have 3:36 rear gears and went with 3:70 gears. This really woke up my car off the line and made it a cruiser on the hiway. It runs about 2280 rpms at 70 mph. Let know if you have any other questions it is all fresh in my mind since I just finished mine about 2 months ago.
Edited by killerkjn on 11-04-19 06:06 PM. Reason for edit: No reason given.
tikiwagon
tikiwagon
Reg: 04-23-04
11-05-19 01:22 AM - Post#2779570
Thanks for your help looking forward to getting it roadworthy too, Is it the flat side of the mounting facing up towards the trans as bowtie overdrives say different? i'm very confused now?
killerkjn
Reg: 12-19-02
11-05-19 06:07 AM - Post#2779580
I did put the flat side up and it seemed to work. Maybe I put mine in wrong. That maybe why I had to file the holes some. I would probably put yours in how bow tie shows and you can flip it over if it doesn’t work.
tikiwagon
tikiwagon
Reg: 04-23-04
11-05-19 11:36 AM - Post#2779601
Great, That's tomorrow's project
killerkjn
Reg: 12-19-02
11-08-19 03:54 PM - Post#2779801
What’s the word on the cross member? Which way did you mount it? I seem to remember trying it flat side down but it didn’t work. So I did flat side up and it works great.
tikiwagon
tikiwagon
Reg: 04-23-04
11-22-19 11:10 AM - Post#2780758
Hi yes i did flat side facing up as the other way the bolts don;t line up any way near, Just rebuilt the prop with new HD center bearing and tried to fit and now this seems to long, Not very happy...
killerkjn
Reg: 12-19-02
11-22-19 11:21 AM - Post#2780761
I had to shorten my front driveshaft 2 1/4 inches because of the difference in transmission lengths.
Execution time: 0.185 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:18 AM
