Username Post: 1979 vette with 454        (Topic#358582)
454 bbc
Reg: 10-25-19
10-25-19 03:56 PM - Post#2778759
hi just got a 1979 vet with a 454 in it that i am having problems with with it not rev up past 3500 rpms with out blowing gas back out of the carb . it has a mild cam / holly 450 carb with new hei distributor and wire and spark plugs gap at .035.
it seem this is happening when the 2nd secondary open up if i take the rpm up slow with out secondries opening i can get it to rev up over 5-5500 rpms before it start to shot gas out of the carb . any help with this would be nice
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
10-25-19 04:43 PM - Post#2778764
    In response to 454 bbc
Sounds like a carb rebuild is in your future. Especially if the car has been sitting for a long time.
454 bbc
Reg: 10-25-19
10-26-19 02:27 PM - Post#2778818
    In response to junkman104
it is brand new holley 650 carb new distributor new plugs
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
10-28-19 01:34 PM - Post#2778973
New is nice but my experience is new is not always correct.
I have run into a Q Jet that failed to lift the fuel metering rods when the back barrels were quickly opened but by going slowly with the throttle you could reach high rpms.
Problem was too much additional air w/o additional fuel.
I would start with, does the back bowl have enough fuel?
454 bbc
Reg: 10-25-19
10-29-19 09:49 AM - Post#2779041
    In response to Mel Foye
thanks what you said is what is happening slow all works good but when the back opens up that were i have the problem
Mel Foye
Mel Foye
Reg: 09-29-00
10-29-19 01:14 PM - Post#2779067
Is this a spread bore? Is this a double pumper?
Vacuum secondaries? Have you driven the car with this new set up. Was it the same? What is your timing set up but I am still thinking carb? Again is the back bowl fuel level where it should be?
mel
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-07-19 04:28 PM - Post#2779744
what city and state are you located in?
its most likely rather simple to diagnose and cure but
an experienced person near you won,t be able to help you out without knowing your location
Mel Foye
Mel Foye
Reg: 09-29-00
11-15-19 05:22 PM - Post#2780248
Did you get it fixed?
Execution time: 0.179 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:50 PM
