Username Post: More 700R4 issues        (Topic#358541)
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
10-22-19 07:56 AM - Post#2778510
My buddy has a 37 Chev with 700R4 that shifts out of first gear very quickly under light/moderate acceleration. However, I know the TV cable is adjusted properly because I did it with the pan off and used a geometry corrector bracket on the Edelbrock carb.
When the throttle is closed (and choke open) the lever is just starting to push on the valve -- around .005" pre-load. And the valve is fully bottomed at WOT.
It also doesn't shift into 4th until 50-60 mph, and then it downshifts back into 3rd when even lightly depressing the throttle MPH. Lock-up is not in the equation when this happens, because we control it with a dash switch. (Switch closed + pressure at 4th gear pressure port.) Axle ratio is 3.36 and tires are 27" tall.
Sure would be nice if the trans worked more like a TH350 with a 4th gear. Those transmissions are very easy to set up with little or no mystery involved. Adjustable modulator, some governor mods, and a TransGo 350-1 valve body kit and you're good to go with predictable and consistent shifts.
IgnitionMan
Reg: 04-15-05
10-22-19 08:12 AM - Post#2778511
    In response to MikeB
Remember that the cable for the 700TH doesn't just set shift points, it also sets, and changes the line pressures the trans operates with. If the cable is correct, but the shift points, or other tans operating issues aren't, it may well be something else in the trans other than the cable adjustment.
Senior Chevytalk Moderator
10-22-19 09:33 AM - Post#2778515
    In response to IgnitionMan
Is it a stock rebuild? Added preload won't hurt it. I'm no expert though. I had to modify my throttle floor plate to get WOT.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
10-29-19 04:52 PM - Post#2779094
It's a stock rebuild. I might trying increasing pre-load a little to see if that helps, even if it prevents WOT. At least it will tell us something.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
11-01-19 11:02 PM - Post#2779343
FWIW, it's more common practice to use a governor re-calibration kit to change shift points and not use the TV cable to do this.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
11-03-19 11:31 AM - Post#2779455
    In response to paulo57509
Not just more common, it's also the right way.
Execution time: 0.098 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:19 PM
