Username Post: High voltage        (Topic#358527)
widall2
Reg: 01-04-09
10-21-19 04:21 AM - Post#2778379
I recently had to replace both the generator and regulator on my 1955 Chevy.The brushes on the generator had worn out and the regulator with the replacement generator only allowed it to charge about 10 amps but at about 13 volts. When I replaced the regulator I now get about 30 amps for a few minutes then down to about 2 amps however after about 2000 RPM the volts are at 15. I am concerned that this will shorten the life of lights and points. I would appreciate any comments. Is this a problem? If so how can I correct without a new regulator or switching to an alternator? Thanks in advance.
10-21-19 05:27 AM - Post#2778382
    In response to widall2
What gage are you using to check the voltage?
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
10-21-19 09:37 AM - Post#2778412
running 30 amps for a few minutes is perfectly normal. You are replacing the juice that you used starting the car.
If it is tapering off after a few minutes, again this is normal. You have replaced the juice you used with the start motor, now all you are needing is the juice to run the ignition, radio, etc.
I would personally install a volt meter. It will give you a better overall picture of what is happening with the electrical system.
One problem with the whole ammeter thing is that ALL of the amperage being used comes through the ammeter. Any loose wires, bad connection, corrosion on those terminals can cause a lot of gremlins.
There's about 2 cents worth.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
10-21-19 02:33 PM - Post#2778444
    In response to beagrizzly
And a well spent two cents it is!
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
widall2
Reg: 01-04-09
10-22-19 04:59 AM - Post#2778491
Thanks for the reply. I do have both a volt meter and an amp meter also a warning light. My concern is the 15 volts other than running at about 13 volts. Will this shorten the life of the light bulbs, coil, points, etc. ?
widall2
Reg: 01-04-09
10-22-19 07:55 AM - Post#2778503
I am using an aftermarket gauge for voltage along with an amp meter and temperature gauge mounter under the dash. I do not recall the company that made the gauges.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
10-24-19 06:16 AM - Post#2778658
Again, I think you are concerned about normal operation.
A fully charged battery holds 2.2 volts per cell. Six cells gives you 13.2 volts total.
It takes more than 13 volts to charge to 13.2. Hence the 15 volts. A digital gauge will probably tell you that you have 14.7 charging instead of the 15 showing on your volt meter. 14.7 is the standard charge rate for a "12 volt" battery.
My two pennies again.
I am now up to 4 cents worth of advice here.
Don't spend it all in one place.
Griff
2005 Yukon XL
2009 Silverado
2011 Escalade ESV
Mel Foye
Mel Foye
Reg: 09-29-00
10-25-19 05:06 PM - Post#2778760
From Southern California Mel to Southern Texas Griff.
So are you saying: If you only need 20 amps after the battery gets recharged you may not have needed to pay big bucks for that 140 amp alternator!!
The charging system is like your boss's hostile daughter who only puts out that which is needed to keep things going. This is not--A No Double Meaning Zone.
Execution time: 0.196 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:10 PM
