Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
12-08-19 05:05 PM - Post#2781740
In response to Jackman
Over at jegs they have a break in material that is grey color, it looks like it sticks on the cam shaft, your hands and anything you touch, it may contain the zinc material.
I have seen STP used as assembly lube and then another can poured in the lifter valley.
But bAck to your point about that material you tried, is it red color?
I' m fixing to do a cam swap I'll be using that grey material and soaking the new lifters in a can of oil then dumping STP in the lifter valley.
Does it work?
I don't know, all I ever used was oil to assemble an engine, it worked
VC56S 2 door Sedan, 40 Years
[image]https://www.chevytalk.org/fusionbb/fbbavatars/a v-3564-1354211547.jpg[/image] |
