Username Post: 305 Chevy cam break in lube?        (Topic#358524)
Jackman
Reg: 10-20-19
10-20-19 05:08 PM - Post#2778354
I have a 1979 305 30 over and all new everything machined and ready for reassembly , question is I coated the cam with Comp cam 103 lube (Link provided) prior to install and dang that stuff is so thin it ran right off the lobes which makes me wonder if I should find thicker lube that will actually stick to the lobes? Thanks in advance!
https://www.ebay.com/itm/COMP-CAMS-103-CAM SHAFT-AN...
Execution time: 0.094 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:25 AM
