Username Post: '59 235 With Captain's Bars?        (Topic#358476)
10-16-19 10:53 AM - Post#2778037
A buddy of mine pulled the 6-banger out of a '59 2-door hardtop that he made a resto-rod out of. I went and looked at the engine this morning. It had lots of built-up dirt and grease, and I haven't found the block casting number yet, but it does have captain's bars behind the starter. Did GM put captain's bars on 235's?
The head is an 848 head, casting date of the head is D 14 1.
I will go back in a few days and find the block casting number, but until then, did 235's ever get captain's bars?
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
10-16-19 11:52 AM - Post#2778040
I thought ONLY 261's had "Captain's Bars". But what do I know? I am Butch/56sedandelivery.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
10-16-19 01:47 PM - Post#2778053
Some 235s had them also.
2blu52
2blu52
Reg: 03-12-02
10-16-19 02:33 PM - Post#2778057
lots of 235 heads sitting on top of 261 blocks.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
10-16-19 06:29 PM - Post#2778064
    In response to 2blu52
I'll find the casting number in the next few days. Thanks.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
10-16-19 06:52 PM - Post#2778065
This might help you, after you find your numbers.
http://www.1954advance-design.com/Stovebolt-engine...
Brian
10-17-19 04:45 AM - Post#2778079
    In response to 55 Shaker
Thanks.
10-17-19 09:21 AM - Post#2778114
I will not say that 235s did not have captain's bars ------------------- BUT, I've only known of captain's bars being on 261s. Thus, if you discover that in fact it is a 261 -------------------- AND IS IN GOOD, REBUILDABLE CONDITION, you have discovered a jewel!
And if it does have a 235 head with steam holes added ------------- so much the better!
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
10-17-19 09:27 AM - Post#2778116
I had a 235 that had captains bars. I was disappointed, I thought I had a 261.
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
10-17-19 11:47 AM - Post#2778125
    In response to Rustchips
3769925! Born on G 23 2. Ran when parked and looks good. It's been stored out of the weather.
Airlifter
Airlifter
Reg: 06-07-15
10-17-19 01:39 PM - Post#2778130
Those numbers indicate a 261 built on July 23, 1962. Great find. Looks like the head was built on April 14,1961. I have read that a 235 head on the 261 gives little boost in compression.
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
2blu52
2blu52
Reg: 03-12-02
10-17-19 01:57 PM - Post#2778131
    In response to Airlifter
Yep it does that!!
THOMAS JEFFERSON
10-17-19 02:23 PM - Post#2778134
Pictures. The engine has been sitting for 30 years, and I don't know if it is rebuildable.
Airlifter
Airlifter
Reg: 06-07-15
10-17-19 03:38 PM - Post#2778143
The 261 that I found presumably was sitting in the truck for 30 years. I ran a compression test, took a look at the bearings,replaced rear main seal and put in the car. So far so good. About 600 miles so far. I would pull the oil pan and head and take a look.
10-17-19 07:30 PM - Post#2778160
Thanks Airlifter. That's my plan.
11-14-19 03:38 PM - Post#2780166
OK, I'm trying to get the bellhousing off so I can pull the clutch and flywheel. The engine is stuck so I can't turn it over to get the pressure plate off. So I've pulled the two upper bellhousing bolts that are accessable from above and outside the bellhousing. I've loosened the two bellhousing bolts that are accessable from reaching under the bellhousing with a 5/8 wrench--I've loosened them a good 1/2 inch on each side.
I cannot break the bellhousing loose. Are there any other bolts holding the bellhousing on besides the 4 I've mentioned?
11-14-19 03:39 PM - Post#2780167
I did pull the head. There is no ridge at the tops of the cylinders, and there ARE steamholes in the block. But no steam holes have been drilled in the head.
2blu52
2blu52
Reg: 03-12-02
11-14-19 07:01 PM - Post#2780186
I have a friend who built a 261 for racing. He did not know then and until I asked him about steam holes he knew nothing. The engine was raced for several years, sold to a rancher who used it to power a home made hay rake for 10 years. The engine is now back with the original owner. Yes it did have a 235 head.
THOMAS JEFFERSON
11-14-19 07:34 PM - Post#2780190
Blu, I think the steam-holes are only needed in severe-duty circumstances. An old guy who ran a NAPA store where I live was helping me one day and asked me what I was working on. I told him a Chevy 261. He told me about working on a combine crew in the 1960's, hauling combines all around the midwest on the back of 2-ton Chevy trucks all summer. They ran those trucks hot, hard and heavy. If they needed to rebuild the engine they'd do it in one night--he'd take the bottom end and replace the bearings while another guy would do the rings from the top of the engine. They finish up, put the head back on and get it going before dawn.
Can anyone answer the question about bellhousing bolts? Are there only 4, or did I miss one? The bellhousing sticks like there are more bolts, but I don't see any. To complicate things there is a lot of debris up inside the bellhousing.
eplantage
Loc: Southern MN
Reg: 03-15-04
11-15-19 04:25 AM - Post#2780204
Robert, I believe there are 6 bolts total. 4 behind the flywheel and 2 at the top of the bellhousing on the outside. You may have to sacrifice the pressure plate to get at the flywheel bolts, if you can get to all those bolts or just use a torch and cut the pressure plate off.
Age: 65 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
11-15-19 08:08 AM - Post#2780212
    In response to eplantage
That's what it acts like, but I can't see anymore bolt heads looking up between the flywheel and the engine.
eplantage
Loc: Southern MN
Reg: 03-15-04
11-15-19 09:57 AM - Post#2780217
The bolts that fasten the bellhousing to the block are to long to remove the bellhousing without taking the flywheel/clutch off first.
11-15-19 11:50 AM - Post#2780227
The two on the bottom I've backed out 1/2 inch. My plan was to get them the rest of the way out after I loosened the bellhousing. I have another bellhousing in my barn--I just remembered it. I'll go check how many mounting holes it has.
11-15-19 01:30 PM - Post#2780234
Yes, there are 6 bolts holding the bellhousing on. 4 from inside the BH and the upper 2 on the outside. Now I've got to cut up the pressure plate and try to get it out so I can removed the clutch and flywheel. I had the exact same situation on the 261 I'm running in my 210, but back then I cut the bellhousing off with a Sawzall. It took hours--that is some tough cast iron. I'd rather not destroy the bellhousing if I can save it.
11-15-19 03:12 PM - Post#2780236
My buddy took pity on me and cut the pressure plate fingers and the clutch middle section out with a torch. Tomorrow I'll go back over and use an impact wrench to remove the flywheel bolts and try to drop the flywheel with pressure plate attached. Looks like there is room.
11-16-19 11:04 AM - Post#2780297
Ok, I pulled the bellhousing without cutting it up, thanks to my buddy. Pulled the oil pan and pulled a main bearing cap. Everything looks good so far, so I bought the engine.
This is why I was tearing everything apart to check. This engine last ran in 1985, when the owner of the '59 2-door Bel Air ran it in that car. But take a look at the way he set up the oil filter lines:
He used reducers to run the 235 bypass oil filter on the 261. Evidently the guy was smart enough to know about the 261's, in 1985, but it looks like he didn't know about the full-flow oil system. The engine appears to be rebuildable. There is no ridge at the tops of the cylinders, but the engine is stuck. Comments? Questions?
eplantage
Loc: Southern MN
Reg: 03-15-04
11-18-19 11:56 AM - Post#2780439
If you're patient you could soak the cylinders with diesel fuel or some type of solvent/mystery oil and see if it will break loose. Is there much surface rust in the cylinders that are at the bottom of the stroke? If so, then there is probably the same in those that are at the top of the stoke beneath the pistons and breaking it loose would be more difficult. I've taken the rods loose from the crank and drove the pistons out with a block of wood on a GMC 6 I was thinking about rebuilding. A lot of work but didn't break anything. Decided against it because of other issues and someone gave me a running 235 from a '54 he was putting a V8 in.
Edited by eplantage on 11-18-19 12:23 PM. Reason for edit: No reason given.
11-18-19 07:16 PM - Post#2780467
Thanks Ed. I pulled the head, and there is rust above the pistons but none below. I did soak the cylinders for 10 days in auto trans fluid/lacquer thinner to no avail. I'll need to pull the crank I think and then pound the pistons down from the top.
I don't think the engine seized up from lack of oil, due to the crazy way the P.O. set up the oil lines, but it must have caused some wear, somewhere. I pulled one of the main bearing caps and didn't see any scoring. No scoring on the cylinder walls that I can see.
Execution time: 0.19 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:07 PM
