Junk86
Reg: 03-15-19
10-14-19 09:17 AM - Post#2777856
Does anyone know where you can purchase a MAP sensor- new for a 1986 Chevy Camaro w/2.8L V6 engine? No one I can locate appears to sell this particular part. Need your help.
10-14-19 02:21 PM - Post#2777883
In response to Junk86
Looks right. https://www.rockauto.com/en/moreinfo.php?pk=100618...
Junk86
Reg: 03-15-19
10-18-19 05:05 AM - Post#2778171
That looks like the one. The only difference I can see is a 3-prong plug. The one on my car has a 4-prong plug. What the 4th wire is for I don't know. I have a 2.8L V6 173 ci engine.
If you know why mine has a 4th wire let me know. Maybe I can change it to a 3-prong plug.
Edited by Junk86 on 10-18-19 05:06 AM. Reason for edit: No reason given.
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
10-20-19 04:15 AM - Post#2778287
I have never seen a 4 prong GM map sensor.
1983G20Van
Loc: Hurst, Texas, USA
Reg: 11-13-02
11-06-19 05:03 PM - Post#2779686
In response to junkman104
86 Camaro V6 should be port fuel injected and it should have a MAF not a MAP sensor. The MAF should be between the airbox and the throttle body. The only thing I can think of that has 4 pins would be the IAC on the throttle body.
1983 G20 Van, 350 TPI, Ported 906 Vortecs, Edelbrock 3817 Base, ASM oversize runners. Reed Custom Roller cam, 700r4, 12 bolt with 3.08 gears, Doug Thorley Tri-Y headers, true duals |
