Username Post: Manifold Asbsolute Pressure Sensor        (Topic#358442)
Junk86
Reg: 03-15-19
10-14-19 09:17 AM - Post#2777856
Does anyone know where you can purchase a MAP sensor- new for a 1986 Chevy Camaro w/2.8L V6 engine? No one I can locate appears to sell this particular part. Need your help.
10-14-19 02:21 PM - Post#2777883
    In response to Junk86
Looks right. https://www.rockauto.com/en/moreinfo.php?pk=100618...
Junk86
Reg: 03-15-19
10-18-19 05:05 AM - Post#2778171
That looks like the one. The only difference I can see is a 3-prong plug. The one on my car has a 4-prong plug. What the 4th wire is for I don't know. I have a 2.8L V6 173 ci engine.
If you know why mine has a 4th wire let me know. Maybe I can change it to a 3-prong plug.
Edited by Junk86 on 10-18-19 05:06 AM. Reason for edit: No reason given.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
10-20-19 04:15 AM - Post#2778287
I have never seen a 4 prong GM map sensor.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
11-06-19 05:03 PM - Post#2779686
    In response to junkman104
86 Camaro V6 should be port fuel injected and it should have a MAF not a MAP sensor. The MAF should be between the airbox and the throttle body. The only thing I can think of that has 4 pins would be the IAC on the throttle body.
Execution time: 0.084 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:03 AM
