Username Post: 1938 temp gauge help        (Topic#358423)
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
10-12-19 02:02 PM - Post#2777743
I have an original temp guage from a '38. I have been testing it to see if it works. When I put it in boiling water, it will run up to about 2/3 of its range. I did blow it out with air and put a little oil on the pivot points. When the needle moves, it is somewhat jerky. It is in tough shape as it has been sitting out in the elements for decades. I did clean the bulb off with some 600 grit sandpaper. I am looking for some insight on this and would appreciate all comments. thanks, greg
Execution time: 0.124 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:18 AM
