Username Post: Holley carb letting fuel into oil pan        (Topic#358417)
BG
Reg: 09-12-07
10-11-19 04:47 PM - Post#2777690
I’ve got a Holley 1850 on my 283 engine. It hadn’t been started in years and isn’t fully back together yet so I’m using a small fuel tank to gravity feed the carb. The engine started and ran pretty good. That was day before yesterday and I left some fuel in the small tank, I didn’t work on it yesterday but today when I went to work on it I noticed the fuel tank was empty and my oil level was high and smells like fuel. I’m wondering if it’s a bad float or needle and seat. What should I check first? Any other ideas? Thanks
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
10-11-19 07:37 PM - Post#2777701
    In response to BG
I would definitely check the needle and seat. But after sitting for that long, I would think a full rebuild would be in order.
BG
Reg: 09-12-07
10-12-19 05:00 AM - Post#2777718
    In response to 5Larry7
I’ll be putting a kit in it but was too curious on how it would run first. I was pleased with how it ran. Thanks
BG
Reg: 09-12-07
10-16-19 03:53 AM - Post#2778004
    In response to BG
Ordered rebuild kit. I checked the floats and they were out of adjustment so readjusted them and that fixed it. Thanks
55Sedan210
55Sedan210
Reg: 12-21-17
03-05-20 11:06 AM - Post#2787986
    In response to BG
Try to get good, reusable gaskets. Save scraping b.s. Also, I use a generous amount of Stabil in all my toys that sit. Had to rebuild a lot less carbs since.
Execution time: 0.121 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:58 AM
