Username Post: 67 c10 wont start        (Topic#358416)
PGradillas
Reg: 10-11-19
10-11-19 01:21 PM - Post#2777679
i was driving the truck, started with no issues. parked for about an hour and wouldnt start. all power turns on. i tried to start with screw driver but there are no sparks seems like no power going to it. when i turn the key back to off and touch with screw driver there is very little spark.
any ideas.
Edited by PGradillas on 10-11-19 01:22 PM. Reason for edit: No reason given.
10-13-19 04:35 PM - Post#2777819
    In response to PGradillas
can you tell us more about your engine and electrical systyem? 1st thing is normaly check all battery cable connections and grounds.
ChromeFinger
ChromeFinger
Loc: Omaha
Reg: 07-08-19
10-17-19 09:15 AM - Post#2778113
    In response to bobb
I agree, we need info. Is this factory or modified?
When you have many electrical system failures, always start at the battery and work your way out. Fusable links next, grounds and connections.
Get a test light on the cheap as this will help, but many are not comfortable with electrical. A digital Multi Meter (DMM) is a good investment for life, if you want to fix these types of issues your self.
There are lots of youtube videos to learn how to use your DMM and become good with it and what you are seeing.
Sorry, but I taught 6 different electrical classes for ACDelco, concluding with lab scopes. So, start simple and go with the basics. Voltage drop is important and the most useful procedure I used in the dealer every time I had an electrical issue. Confirm B+, Grounds and fuses. What works and what does not. Can be a simple ignition switch as a screwdriver on the starter may not be touching the right terminals. This is a spot that's hard to see.
Let us know!
Execution time: 0.136 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:38 AM
